Hi, Probably a dumb question to all you who understand the mysteries of linux!
I used XLD to rip my CD’s, without modifying any settings. Once on my USB external drive, I connect to the PI and through the interface look at the music. Some albums are split, so a compilation is split into the various artists, some albums have artwork, some don’t, some appear in artist and not album
I also have files that are flac, aiff and DXD I’ve downloaded. I didn’t put them through XLD, just copied them to the drive. They also suffer from no Artwork at times, in some cases I can find them from artist, but not in album and so on.
I have scrubbed the 8Gb drive with Volumio and reloaded, and, some of the files appear ok that previously weren’t appearing properly
Any thoughts?
), therefore you need to manually re-scan your drive using the webUI or the MPD command.
