When I run mpc in the command line during an update, it says
$ mpc status
Updating DB (#1) ...
volume: n/a repeat: off random: off single: off consume: off
What does that “#1” mean?
$ mpc status
The count of updates. If you starts mpc update again a few minutes later, it will show you #2.
OK, so when does it restart the count? Does it restart at #1 only when the mpd service is restarted? Or is it counting simultaneous updates? Confused because when I’m trying to run Client175 I get very large numbers like this after only a few minutes of running.
$ mpc
Updating DB (#2158) ...
Then if I check a minute later, the update line is gone.
Yes.
No.
