So sorry, I didn’t understand what you were asking for (printed the output before mounting, stopped the command and printed the output after mounting
So here is a fresh new test with the command launched before mounting and all the output until the mounting stopped :
volumio@volumio:~$ sudo journalctl -f
-- Logs begin at Sat 2016-08-20 16:39:20 UTC. --
Sep 20 13:22:06 volumio systemd[8747]: Reached target Basic System.
Sep 20 13:22:06 volumio systemd[8747]: Starting Default.
Sep 20 13:22:06 volumio systemd[8747]: Reached target Default.
Sep 20 13:22:06 volumio systemd[8747]: Startup finished in 31ms.
Sep 20 13:22:06 volumio systemd[1]: Started User Manager for UID 1000.
Sep 20 13:22:06 volumio sshd[8726]: pam_env(sshd:session): Unable to open env file: /etc/default/locale: No such file or directory
Sep 20 13:22:07 volumio sshd[8726]: lastlog_openseek: Couldn't stat /var/log/lastlog: No such file or directory
Sep 20 13:22:18 volumio sudo[8806]: volumio : TTY=pts/0 ; PWD=/home/volumio ; USER=root ; COMMAND=/bin/journalctl -f
Sep 20 13:22:18 volumio sudo[8806]: pam_unix(sudo:session): session opened for user root by volumio(uid=0)
Sep 20 13:22:31 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
Sep 20 13:22:31 volumio volumio[602]: info: CoreCommandRouter::volumioGetState
Sep 20 13:22:31 volumio volumio[602]: info: [1474377751066] CoreStateMachine::getState
Sep 20 13:22:31 volumio volumio[602]: info: [1474377751068] CorePlayQueue::getTrack 0
Sep 20 13:22:31 volumio volumio[602]: [1474377751070] ---------------------------- Client requests Volumio state
Sep 20 13:22:31 volumio volumio[602]: info: [1474377751075] Listing playlists
Sep 20 13:22:31 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Sep 20 13:22:31 volumio volumio[602]: Plugin multiroom or method getMultiroom not found
Sep 20 13:22:31 volumio volumio[602]: [1474377751081] ---------------------------- Client requests Menu Items
Sep 20 13:22:31 volumio volumio[602]: info: [1474377751082] InterfaceWebUI::pushState
Sep 20 13:22:31 volumio volumio[602]: info: [1474377751087] ------------------------------ 23ms
Sep 20 13:22:31 volumio volumio[602]: info: [1474377751095] ------------------------------ 14ms
Sep 20 13:22:38 volumio volumio[602]: info: CoreCommandRouter::getUIConfigOnPlugin
Sep 20 13:22:38 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Sep 20 13:22:38 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: networkfs , listShares
Sep 20 13:22:42 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Sep 20 13:22:43 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: networkfs , discoverShares
Sep 20 13:22:46 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Sep 20 13:22:50 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Sep 20 13:22:54 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Sep 20 13:22:58 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Sep 20 13:23:02 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Sep 20 13:23:06 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Sep 20 13:23:07 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: networkfs , addShare
Sep 20 13:23:07 volumio volumio[602]: info: Adding a new share
Sep 20 13:23:07 volumio volumio[602]: info: No correspondence found in configuration for share Datastation on IP datastation.local
Sep 20 13:23:07 volumio sudo[9012]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/mount -t cifs -o guest,ro,dir_mode=0777,file_mode=0666,iocharset=utf8,noauto //datastation.local/Datastation Drives SMB /mnt/NAS/Datastation
Sep 20 13:23:07 volumio sudo[9012]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 20 13:23:07 volumio kernel: FS-Cache: Netfs 'cifs' registered for caching
Sep 20 13:23:07 volumio kernel: Key type cifs.spnego registered
Sep 20 13:23:07 volumio kernel: Key type cifs.idmap registered
Sep 20 13:23:07 volumio sudo[9012]: pam_unix(sudo:session): session closed for user root
Sep 20 13:23:07 volumio mpd[637]: client: [2] opened from local
Sep 20 13:23:07 volumio mpd[637]: client: [2] closed
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787566] ControllerMpd::sendMpdCommand status
Sep 20 13:23:07 volumio volumio[602]: info: Mpd Status Update: update
Sep 20 13:23:07 volumio volumio[602]: [1474377787574] ---------------------------- MPD announces state update
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787579] sending command...
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787581] ControllerMpd::getState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787583] ControllerMpd::sendMpdCommand status
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787583] sending command...
Sep 20 13:23:07 volumio mpd[637]: errno: Failed to open 'NAS/Datastation/Media': Permission denied
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787594] Database update started
Sep 20 13:23:07 volumio volumio[602]: COMMON.MY_MUSIC
Sep 20 13:23:07 volumio volumio[602]: [ 'COMMON', 'MY_MUSIC' ]
Sep 20 13:23:07 volumio volumio[602]: COMMON.SCAN_DB
Sep 20 13:23:07 volumio volumio[602]: [ 'COMMON', 'SCAN_DB' ]
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787610] ControllerMpd::sendMpdCommand status
Sep 20 13:23:07 volumio volumio[602]: [1474377787612] ---------------------------- MPD announces state update
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787614] sending command...
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787616] ControllerMpd::getState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787617] ControllerMpd::sendMpdCommand status
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787618] sending command...
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787620] parsing response...
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787622] parsing response...
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787623] parsing response...
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787626] ControllerMpd::parseState
Sep 20 13:23:07 volumio volumio[602]: info: Command Router : Notfying DB Updatefalse
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787630] ControllerMpd::parseState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787631] ControllerMpd::parseState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787634] ControllerMpd::pushState
Sep 20 13:23:07 volumio volumio[602]: info: CoreCommandRouter::servicePushState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787639] CoreStateMachine::syncState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787640] CorePlayQueue::getTrack 0
Sep 20 13:23:07 volumio volumio[602]: info: STATE SERVICE {"status":"stop","position":null,"seek":null,"duration":null,"samplerate":null,"bitdepth":null,"channels":null,"random":false,"updatedb":false,"repeat":false,"isStreaming":false,"title":null,"artist":null,"album":null,"uri":null}
Sep 20 13:23:07 volumio volumio[602]: info: CURRENT POSITION 0
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787642] CoreStateMachine::syncState stateService stop
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787642] CoreStateMachine::syncState currentStatus stop
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787643] CoreStateMachine::pushState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787643] CoreStateMachine::getState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787644] CorePlayQueue::getTrack 0
Sep 20 13:23:07 volumio volumio[602]: info: CoreCommandRouter::volumioPushState
Sep 20 13:23:07 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787646] InterfaceWebUI::pushState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787648] No code
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787649] CoreStateMachine::pushState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787649] CoreStateMachine::getState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787650] CorePlayQueue::getTrack 0
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787652] InterfaceWebUI::pushState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787657] ------------------------------ 84ms
Sep 20 13:23:07 volumio volumio[602]: info: Pushing Favourites {"service":"mpd","uri":"","favourite":false}
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787663] parsing response...
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787664] ControllerMpd::parseState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787665] ControllerMpd::pushState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787666] CoreStateMachine::syncState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787666] CorePlayQueue::getTrack 0
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787669] CoreStateMachine::syncState stateService stop
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787669] CoreStateMachine::syncState currentStatus stop
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787670] CoreStateMachine::pushState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787670] CoreStateMachine::getState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787671] CorePlayQueue::getTrack 0
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787672] InterfaceWebUI::pushState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787675] No code
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787675] CoreStateMachine::pushState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787676] CoreStateMachine::getState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787676] CorePlayQueue::getTrack 0
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787684] InterfaceWebUI::pushState
Sep 20 13:23:07 volumio volumio[602]: info: [1474377787691] ------------------------------ 80ms
Sep 20 13:23:08 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: networkfs , listShares
Sep 20 13:23:10 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Sep 20 13:23:14 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Sep 20 13:23:18 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Sep 20 13:23:22 volumio volumio[602]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
So I think the relevant log here is :
Any idea why this happens ?
As user volumio
I’m able to browse this folder with no problem, can’t understand why this happens to me but everyone seems to be able to mount his CIFS share ![:cry: :cry:](https://community.volumio.com/images/emoji/apple/cry.png?v=12)
Thanks for your attention !
