Hi, i’m on a rasp 3b and Volumio 2.
my music is recorded on a NAS server but Volumio mounts the folder only in read-only mode. It is possible mount in read / write mode? I’m using GUI standar mount web interface…
Hi @cherrera
Any reason why you’re not on the current version? V3 is stable and maintained.
Can you screenshot your settings in the network section of Sources.
Maybe this helps…
https://forums.linuxmint.com/viewtopic.php?t=264422
Thanks @dvo ,
If I change the fstab file manually from the console, will Volumio work correctly?
I don’t know, i don’t have mounted drives i only looked it up online.
Nice that you found a option
