I need help. I have installed Volumio 3, but for some reason I am not able to mount the network driver. I have used the same parameters that I use with Volumio 2, but they do not work. I also have try to use vers=1.0 and vers=2.0 but no luck.
is there something else that I need to use with this version?
Have you put the IP address of the nas in NAS IP Address box? Volumio often puts a name there.
Also add the Samba username and password. Remember the slashes are \ not / in the path.
You could also try sec=ntlm in the options field.
Nope, does not work.
