I have installed Volumio 2 and tried to connect my NAS (Buffalo LS441DE) but couldn’t succeed.
My NAS IP address: 192.168.1.3
My NAS path:
My PI with Volumio: 192.168.0.20
I used SSH command line
mount -t cifs /mnt/myNAS //192.168.1.3/share/Music -o username=uid,password=pwd,ro,noatime,sec=ntlmv2 --verbose
but the result was
On my MACBOOK, I can connect to my NAS without any issues.
Can Volumio allow to mount NAS in different IP subnet?
Any helps for me? Thanks
vtrpns
January 6, 2017, 2:15am
2
Could you describe your network topology a little bit?
For the volumio device
does it have a good default route in place? (ssh in and run “ip route”, and paste the output here)
can you ping the NAS from the volumio device?
My network topology:
Internet
Modem--------NAS (192.168.1.3)
WIFI router----------volumio (192.168.0.19)
This means:
Internet modem IP: 192.168.1.1
NAS connects directly to this device, IP: 192.168.1.3
WIFI router IP: 192.168.0.1
WIFI router connects to the modem via its WAN port
WIFI router provide DHCP to volumio, IP: 192.168.0.19
I can ping to the NAS
volumio@volumio:~$ sudo ping 192.168.1.3
PING 192.168.1.3 (192.168.1.3) 56(84) bytes of data.
64 bytes from 192.168.1.3: icmp_seq=1 ttl=63 time=14.9 ms
64 bytes from 192.168.1.3: icmp_seq=2 ttl=63 time=9.51 ms
64 bytes from 192.168.1.3: icmp_seq=3 ttl=63 time=150 ms
^C
— 192.168.1.3 ping statistics —
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 9.516/58.199/150.143/65.051 ms
and here is the ‘ip route’ command
By the way, my NAS is Buffalo LinkStation LS421DE with latest firmware. Is there any issue when connecting volumio with Buffalo LinkStation?
vtrpns
January 9, 2017, 7:47pm
4
That’s bizarre; I was hoping it was going to be a simple network reachability thing.
Can you even get a list of shares out of the NAS?
Something like
smbclient -I 192.168.1.3 -U guest% -L foo
Just in case it helps at all, here’s the mount options I see
//blah/music on /mnt/NAS/music type cifs (ro,relatime,vers=1.0,sec=none,cache=strict,domain=blah,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.0.210,unix,posixpaths,serverino,mapposix,acl,rsize=1048576,wsize=1048576,actimeo=1)
No idea of this helps
Sudo nano /etc/dhcpcd.conf
Change 255.255.255.0 to 255.255.0.0
