Hi guys
I´m having trouble mounting a Windows share that is hidden and is shared with Everyone (no user and pass)
No matter what i try, the share will not mount successfully. The share is on a Windows Server 2003.
Hi guys
Does it work if the share is not hidden (not sure what you mean by that btw)?
In Windows you can create hidden shares (share$)
If it´s hidden, it doesn´t show up if you look for it, but you can browse to it if you know the path. Maybe similar to hidden SSID
It works if the share is not hidden. So it seems that Volumio does not work with hidden shares
