Motivo - ethernet and WiFi
I have the Motivo hooked up to both ethernet (1gb/s) and WiFi (300-400mb/s).
I prefer ethernet for sound quality but can’t use Tidal connect on my phone without WiFi.
Which connection does the Motivo use when both are available?
Hello!
The ethernet connection takes priority when both connections are enabled, but it is not necessary to have both active simultaneously.
For using Tidal Connect, there’s no need to connect the Motivo to Wi-Fi; it will function properly even via an ethernet connection.
If you need further assistance, feel free to contact us at: support at volumio dot org
Thanks!
Davide
VOLUMIO TECH SUPPORT
