mono output?
Hi all. I am looking to make a simple mono speaker to stream my music library. My current “cheap” dac is stereo. Does anyone have any suggestions on what hardware and software adjustments I should use?
Ie.
Stereo out+???+Mono amp
Volumio output only over left channel+stereo/mono amp?
Thanks!
Just in case anyone reads this, there’s a plugin for this: github.com/balbuze/volumio-plug … tereo2mono
Hi, thanks for the information.
Have you found any way to manage volume levels separately for both speakers?
Sorry, but my intention is to run mono audio in 2 rooms from only 1 raspberry and to be able to change volume separately.
To be fair, it would be really amazing to be able to run 2 instances of folumio from the same raspberry, one for each speaker in mono, that that seems a dream for me.
