and changed the asound.conf file, but the output through volumio is still in stereo. Is volumio not using this file? It do I need to change the settings somewhere?
I did previously try the volstereo2mono plugin, but that falls over with Spotify for me.
volstereo2mono worked on first install. However, when I tried to play spotify through volumio using volspotconnect2 the audio stopped completely. I couldn’t get back to mono after that.
If you want, I prepared a mod version of volspotconnect2 that should work with volstereo2mono.
Just unzip the attached file in /data/plugin/music_services/volspotconnect2. It will overwrite index.js
enable volstereo2mono
disable and enable volspotconnect.
If no sound, reboot.
let me know.
volumio@amp-zero:/$ miniunzip index.zip -d ./data/plugins/music_service/volspotconnect2
MiniUnz 1.01b, demo of zLib + Unz package written by Gilles Vollant
more info at http://www.winimage.com/zLibDll/unzip.html
Cannot open index.zip or index.zip.zip[/code]
This is probably due to my extremely limited linux knowledge.
So I unzipped it and then copied it into the volspotconnect2 folder where it created an index.js1 file. I just removed the original and renamed this one.
I tried installing the dev version, but despite it appearing to install properly, the plugin does not appear in the UI. (Same issue logged in github a few days back).
OK. I have exactly the same issue. It doesn’t seems to be common to build mono speaker, but I did it. Now, I want to use spotify connect but with mono output. After installation of stereo2mono plugin, there is no sound from Spotify connect 2 (0.9.1 version). But there is from other sources, such as web radio.
I don’t want to use the modified index.js as it is the old version. Meanwhile there were issue with spotify connect plug-in, so the “big” guys have to fix it.
Any idea how to make mono output work alongside spotify connect?
RPi 0 W
Justboom AMP Zero
Volumio 2.565
Spotify connect2 0.9.1
