I need mono output on both speaker so I created a asound.conf like that :
It’s working from squeezelite, but now I cannot play music from volumio or dlna. I have the following error : Failed to open alsa device hw:2,0 : device or resource busy.
Got it working !
I had to change audio output to default loopback default audio device in squeezelite configuration
No Idea why (I tested all of them to find this one working).
Nice.
Yes, the output must be redirected to loopback in order to go through the plugin.
This is the case for mpd, Spotify, Spotify connect.
But not squeeze lite because it does not use standard mechanism to update its output…
