What does that mean? In post #9 you wrote
If you should not be referring to any (visual) display problems but to the touch issues
you are mentioning, have a little patience:
Hi Gvolt! mind me to ask you , iâm having a hard to work with touch function of this , i am using rpi 3b+ and a 4inch HDMI Display-C - LCD wiki and from a fresh volumio OS and i use these modify txt above the display is working but the touch function isnât,
Please post the results of
cat /boot/userconfig.txt
ls -al /usr/share/X11/xorg.conf.d
ls -al /dev/input
cat /var/log/Xorg.0.log
P.S. What is your Volumio version?
volumio@volumio:~$ cat /boot/userconfig.txt
dtparam=i2c_arm=on
dtparam=spi=on
config_hdmi_boost=7
hdmi_group=2
hdmi_mode=87
hdmi_drive=2
hdmi_cvt 480 800 60 6 0 0 0
dtoverlay=ads7846
dtparam=cs=1
dtparam=penirq=25
dtparam=penirq_pull=2
dtparam=speed=50000
dtparam=swapxy=0
dtparam=pmax=255
dtparam=xohms=150
dtparam=xmin=200
dtparam=xmax=3900
dtparam=ymin=200
dtparam=ymax=3900
display_rotate=3
volumio@volumio:~$
volumio@volumio:~$ ls -al /usr/share/X11/xorg.conf.d
total 13
drwxr-xr-x 2 root root 1024 Jul 3 09:40 .
drwxr-xr-x 1 root root 1024 Jul 3 09:41 ..
-rw-r--r-- 1 root root 92 Feb 8 2019 10-amdgpu.conf
-rw-r--r-- 1 root root 1350 Apr 4 2023 10-quirks.conf
-rw-r--r-- 1 root root 92 Apr 7 2019 10-radeon.conf
-rw-r--r-- 1 root root 1429 Mar 31 2019 40-libinput.conf
-rw-r--r-- 1 root root 2747 Jun 26 2017 70-wacom.conf
volumio@volumio:~$ ls -al /dev/input
total 0
drwxr-xr-x 3 root root 120 Jul 22 17:15 .
drwxr-xr-x 15 root root 3680 Jul 22 17:16 ..
drwxr-xr-x 2 root root 60 Jul 22 17:15 by-path
crw-rw---- 1 root input 13, 64 Jul 22 17:15 event0
crw-rw---- 1 root input 13, 63 Jul 22 17:15 mice
crw-rw---- 1 root input 13, 32 Jul 22 17:15 mouse0
volumio@volumio:~$ cat /var/log/Xorg.0.log
[ 58.928]
X.Org X Server 1.20.4
[ 58.928] Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
[ 58.928] Current Operating System: Linux volumio 6.1.77-v7+ #1730 SMP Thu Feb 8 15:17:51 GMT 2024 armv7l
[ 58.928] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyS0,115200 console=tty1 imgpart=UUID=826680f7-a407-4ab9-8bd5-1855bda526fd imgfile=/volumio_current.sqsh bootpart=UUID=FD90-ED9E datapart=UUID=fecb0823-2e5b-4bba-9498-dd37b5084148 uuidconfig=cmdline.txt pcie_aspm=off pci=pcie_bus_safe rootwait bootdelay=7 logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0 nodebug use_kmsg=no
[ 58.928] Build Date: 04 April 2023 07:50:56AM
[ 58.928] xorg-server 2:1.20.4-1+rpt4+deb10u9 (https://www.debian.org/support)
[ 58.928] Current version of pixman: 0.36.0
[ 58.928] Before reporting problems, check http://wiki.x.org
[ 58.928] Markers: (--) probed, (**) from config file, (==) default setting,
[ 58.929] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Jul 22 19:01:01 2024
[ 58.961] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 58.961] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 58.970] (==) No Layout section. Using the first Screen section.
[ 58.970] (==) No screen section available. Using defaults.
[ 58.970] (**) |-->Screen "Default Screen Section" (0)
[ 58.970] (**) | |-->Monitor "<default monitor>"
[ 58.978] (==) No monitor specified for screen "Default Screen Section".
[ 58.978] (==) Automatically adding devices
[ 58.978] (==) Automatically enabling devices
[ 58.978] (==) Automatically adding GPU devices
[ 58.988] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 59.022] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 59.022] Entry deleted from font path.
[ 59.033] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 59.033] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 59.033] (II) The server relies on udev to provide the list of input devices.
[ 59.033] (II) Loader magic: 0x1fdf80
[ 59.033] (II) Module ABI versions:
[ 59.033] X.Org ANSI C Emulation: 0.4
[ 59.033] X.Org Video Driver: 24.0
[ 59.033] X.Org XInput driver : 24.1
[ 59.033] X.Org Server Extension : 10.0
[ 59.037] (--) using VT number 2
[ 59.038] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 59.038] (II) no primary bus or device found
[ 59.039] (II) LoadModule: "glx"
[ 59.041] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 59.130] (II) Module glx: vendor="X.Org Foundation"
[ 59.130] compiled for 1.20.4, module version = 1.0.0
[ 59.130] ABI class: X.Org Server Extension, version 10.0
[ 59.131] (==) Matched modesetting as autoconfigured driver 0
[ 59.131] (==) Matched fbdev as autoconfigured driver 1
[ 59.131] (==) Assigned the driver to the xf86ConfigLayout
[ 59.131] (II) LoadModule: "modesetting"
[ 59.140] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 59.146] (II) Module modesetting: vendor="X.Org Foundation"
[ 59.146] compiled for 1.20.4, module version = 1.20.4
[ 59.146] Module class: X.Org Video Driver
[ 59.146] ABI class: X.Org Video Driver, version 24.0
[ 59.146] (II) LoadModule: "fbdev"
[ 59.147] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 59.149] (II) Module fbdev: vendor="X.Org Foundation"
[ 59.150] compiled for 1.20.3, module version = 0.5.0
[ 59.150] Module class: X.Org Video Driver
[ 59.150] ABI class: X.Org Video Driver, version 24.0
[ 59.150] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 59.150] (II) FBDEV: driver for framebuffer: fbdev
[ 59.158] (WW) Falling back to old probe method for modesetting
[ 59.159] (EE) open /dev/dri/card0: No such file or directory
[ 59.159] (WW) Falling back to old probe method for fbdev
[ 59.159] (II) Loading sub module "fbdevhw"
[ 59.159] (II) LoadModule: "fbdevhw"
[ 59.159] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 59.163] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 59.163] compiled for 1.20.4, module version = 0.0.2
[ 59.163] ABI class: X.Org Video Driver, version 24.0
[ 59.163] (II) FBDEV(0): using default device
[ 59.163] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 59.163] (II) FBDEV(0): Creating default Display subsection in Screen section
[ 59.163] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 59.163] (==) FBDEV(0): RGB weight 888
[ 59.163] (==) FBDEV(0): Default visual is TrueColor
[ 59.164] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 59.164] (II) FBDEV(0): hardware: BCM2708 FB (video memory: 1500kB)
[ 59.164] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 59.164] (II) FBDEV(0): checking modes against framebuffer device...
[ 59.164] (II) FBDEV(0): checking modes against monitor...
[ 59.164] (II) FBDEV(0): Virtual size is 800x480 (pitch 800)
[ 59.164] (**) FBDEV(0): Built-in mode "current"
[ 59.164] (==) FBDEV(0): DPI set to (96, 96)
[ 59.164] (II) Loading sub module "fb"
[ 59.164] (II) LoadModule: "fb"
[ 59.164] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 59.171] (II) Module fb: vendor="X.Org Foundation"
[ 59.171] compiled for 1.20.4, module version = 1.0.0
[ 59.171] ABI class: X.Org ANSI C Emulation, version 0.4
[ 59.171] (**) FBDEV(0): using shadow framebuffer
[ 59.171] (II) Loading sub module "shadow"
[ 59.171] (II) LoadModule: "shadow"
[ 59.172] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 59.176] (II) Module shadow: vendor="X.Org Foundation"
[ 59.176] compiled for 1.20.4, module version = 1.1.0
[ 59.176] ABI class: X.Org ANSI C Emulation, version 0.4
[ 59.176] (II) UnloadModule: "modesetting"
[ 59.176] (II) Unloading modesetting
[ 59.201] (==) FBDEV(0): Backing store enabled
[ 59.208] (==) FBDEV(0): DPMS enabled
[ 59.210] (II) Initializing extension Generic Event Extension
[ 59.212] (II) Initializing extension SHAPE
[ 59.214] (II) Initializing extension MIT-SHM
[ 59.216] (II) Initializing extension XInputExtension
[ 59.226] (II) Initializing extension XTEST
[ 59.228] (II) Initializing extension BIG-REQUESTS
[ 59.230] (II) Initializing extension SYNC
[ 59.232] (II) Initializing extension XKEYBOARD
[ 59.234] (II) Initializing extension XC-MISC
[ 59.236] (II) Initializing extension SECURITY
[ 59.238] (II) Initializing extension XFIXES
[ 59.240] (II) Initializing extension RENDER
[ 59.242] (II) Initializing extension RANDR
[ 59.246] (II) Initializing extension COMPOSITE
[ 59.249] (II) Initializing extension DAMAGE
[ 59.251] (II) Initializing extension MIT-SCREEN-SAVER
[ 59.253] (II) Initializing extension DOUBLE-BUFFER
[ 59.255] (II) Initializing extension RECORD
[ 59.257] (II) Initializing extension DPMS
[ 59.259] (II) Initializing extension Present
[ 59.261] (II) Initializing extension DRI3
[ 59.261] (II) Initializing extension X-Resource
[ 59.263] (II) Initializing extension XVideo
[ 59.265] (II) Initializing extension XVideo-MotionCompensation
[ 59.265] (II) Initializing extension SELinux
[ 59.265] (II) SELinux: Disabled on system
[ 59.265] (II) Initializing extension GLX
[ 59.267] (II) AIGLX: Screen 0 is not DRI2 capable
[ 61.246] (II) IGLX: Loaded and initialized swrast
[ 61.246] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 61.246] (II) Initializing extension XFree86-VidModeExtension
[ 61.248] (II) Initializing extension XFree86-DGA
[ 61.250] (II) Initializing extension XFree86-DRI
[ 61.253] (II) Initializing extension DRI2
[ 61.731] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/event0)
[ 61.731] (**) ADS7846 Touchscreen: Applying InputClass "libinput touchscreen catchall"
[ 61.731] (**) ADS7846 Touchscreen: Applying InputClass "Touch rotation"
[ 61.731] (II) LoadModule: "libinput"
[ 61.732] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 61.779] (II) Module libinput: vendor="X.Org Foundation"
[ 61.779] compiled for 1.20.3, module version = 0.28.2
[ 61.779] Module class: X.Org XInput Driver
[ 61.779] ABI class: X.Org XInput driver, version 24.1
[ 61.779] (II) Using input driver 'libinput' for 'ADS7846 Touchscreen'
[ 61.779] (**) ADS7846 Touchscreen: always reports core events
[ 61.780] (**) Option "Device" "/dev/input/event0"
[ 61.780] (**) Option "_source" "server/udev"
[ 61.815] (II) event0 - ADS7846 Touchscreen: is tagged by udev as: Touchscreen
[ 61.817] (II) event0 - ADS7846 Touchscreen: device is a touch device
[ 61.818] (II) event0 - ADS7846 Touchscreen: device removed
[ 61.860] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f204000.spi/spi_master/spi0/spi0.1/input/input0/event0"
[ 61.861] (II) XINPUT: Adding extended input device "ADS7846 Touchscreen" (type: TOUCHSCREEN, id 6)
[ 61.861] (**) Option "AccelerationScheme" "none"
[ 61.861] (**) ADS7846 Touchscreen: (accel) selected scheme none/0
[ 61.861] (**) ADS7846 Touchscreen: (accel) acceleration factor: 2.000
[ 61.861] (**) ADS7846 Touchscreen: (accel) acceleration threshold: 4
[ 61.871] (II) event0 - ADS7846 Touchscreen: is tagged by udev as: Touchscreen
[ 61.873] (II) event0 - ADS7846 Touchscreen: device is a touch device
[ 61.878] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/mouse0)
[ 61.878] (II) No input driver specified, ignoring this device.
[ 61.878] (II) This device may have been added with another device file.
Version of Volumio: 3.703
Hostname: volumio
Kernel: 6.1.77-v7+
Governor: performance
Uptime: 0 days, 0 Hrs, 7 Minutes, 10 Seconds
Network info
Interface: eth0
IP Address: 192.168.100.159
MAC Address: b8:27:eb:9c:87:98
Type: wired
Speed: 100Mb/s
Audio info
Hw audio configured: ST400 Dac (PCM5122) - Amp
Mixer type: undefined
Number of channels:
Supported sample rate:
Board info
Model: Raspberry Pi 3 Model B Plus Rev 1.3 Raspberry Pi / 3B+ - 1.3 /
Version: a020d3 / 3B+ - 1.3
Firmware Version: Oct 17 2023 15:42:39 - 30f0c5e4d076da3ab4f341d88e7d505760b93ad7
CPU info
Brand: BCM2837
Speed: 1.4 GHz
Family: Cortex-A53
Model: 4
Number of cores: 4
Physical cores: 4
Average load: 10%
Temperature: 52°C
Memory info
Memory: 891692 Ko
Free: 85048 Ko
Used: 806644 Ko
Software info
Mpd version: Music Player Daemon 0.23.15 (0.23.15)
Storage info
INTERNAL storage - Size: 56440Mo
Used: 1041Mo
Available for storage: 52483Mo (93%)
Please install xserver-xorg-input-evdev running
sudo apt-get -y install xserver-xorg-input-evdev
After that execute
sudo cp /usr/share/X11/xorg.conf.d/10-evdev.conf /usr/share/X11/xorg.conf.d/45-evdev.conf
and reboot.
Hi gvolt! i tried t execute this unfortunately nothing has change. touch screen function still not working after reboot
Pease post the output of
cat /usr/share/X11/xorg.conf.d/45-evdev.conf
You may also try the following:
sudo mv /boot/overlays/ads7846.dtbo /boot/overlays/ads7846.dtbo.bak
sudo curl -L https://github.com/goodtft/LCD-show/raw/master/usr/ads7846-overlay.dtb -o /boot/overlays/ads7846-overlay.dtbo
After that reboot.
hi hereâs the output volumio@volumio:~$
# Catch-all evdev loader for udev-based systems
# We don't simply match on any device since that also adds accelerometers
# and other devices that we don't really want to use. The list below
# matches everything but joysticks.
Section "InputClass"
Identifier "evdev pointer catchall"
MatchIsPointer "on"
MatchDevicePath "/dev/input/event*"
Driver "evdev"
EndSection
Identifier "evdev keyboard catchall"
MatchIsKeyboard "on"
Driver "evdev"
EndSection
Identifier "evdev touchpad catchall"
MatchIsTouchpad "on"
Driver "evdev"
EndSection
Identifier "evdev tablet catchall"
MatchIsTablet "on"
Driver "evdev"
EndSection
Identifier "evdev touchscreen catchall"
MatchIsTouchscreen "on"
Driver "evdev"
EndSection
volumio@volumio:~$
Please again post the output of
Although I suspect you will see nothing please run
cat /dev/input/event*
and check if touching the screen shows some reaction (weird characters). You can exit this test by hitting Ctrl+c
Did you already try the alternative ads7846 overlay file from goodtft?
[ 47.400]
[ 47.400] Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
[ 47.400] Current Operating System: Linux volumio 6.1.69-v7+ #1710 SMP Thu Dec 21 13:14:13 GMT 2023 armv7l
[ 47.400] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyS0,115200 console=tty1 imgpart=UUID=8543fa12-4125-4451-a534-cec5480e0606 imgfile=/volumio_current.sqsh bootpart=UUID=9C48-E5A3 datapart=UUID=f7cca1c6-391b-47a8-9c19-3b1948539def uuidconfig=cmdline.txt pcie_aspm=off pci=pcie_bus_safe rootwait bootdelay=7 logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0 nodebug use_kmsg=no
[ 47.401] Build Date: 04 April 2023 07:50:56AM
[ 47.401] xorg-server 2:1.20.4-1+rpt4+deb10u9 (Debian -- User Support)
[ 47.401] Current version of pixman: 0.36.0
[ 47.401] Before reporting problems, check http://wiki.x.org
[ 47.401] Markers: (â) probed, () from config file, (==) default setting,
[ 47.401] (==) Log file: â/var/log/Xorg.0.logâ, Time: Tue Oct 22 10:09:47 2024
[ 47.407] (==) Using config directory: â/etc/X11/xorg.conf.dâ
[ 47.407] (==) Using system config directory â/usr/share/X11/xorg.conf.dâ
[ 47.411] (==) No Layout section. Using the first Screen section.
[ 47.411] (==) No screen section available. Using defaults.
[ 47.411] () |â>Screen âDefault Screen Sectionâ (0)
[ 47.411] (**) | |â>Monitor ââ
[ 47.415] (==) No monitor specified for screen âDefault Screen Sectionâ.
[ 47.415] (==) Automatically adding devices
[ 47.415] (==) Automatically enabling devices
[ 47.415] (==) Automatically adding GPU devices
[ 47.415] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 47.417] (WW) The directory â/usr/share/fonts/X11/cyrillicâ does not exist.
[ 47.417] Entry deleted from font path.
[ 47.422] (==) FontPath set to:
built-ins
[ 47.422] (==) ModulePath set to â/usr/lib/xorg/modulesâ
[ 47.422] (II) The server relies on udev to provide the list of input devices.
[ 47.422] (II) Loader magic: 0x1fdf80
[ 47.422] (II) Module ABI versions:
[ 47.422] X.Org ANSI C Emulation: 0.4
[ 47.422] X.Org Video Driver: 24.0
[ 47.422] X.Org XInput driver : 24.1
[ 47.422] X.Org Server Extension : 10.0
[ 47.424] (â) using VT number 2
[ 47.424] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 47.424] (II) no primary bus or device found
[ 47.424] (II) LoadModule: âglxâ
[ 47.426] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 47.456] (II) Module glx: vendor=âX.Org Foundationâ
[ 47.456] compiled for 1.20.4, module version = 1.0.0
[ 47.456] ABI class: X.Org Server Extension, version 10.0
[ 47.456] (==) Matched modesetting as autoconfigured driver 0
[ 47.456] (==) Matched fbdev as autoconfigured driver 1
[ 47.456] (==) Assigned the driver to the xf86ConfigLayout
[ 47.456] (II) LoadModule: âmodesettingâ
[ 47.458] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 47.462] (II) Module modesetting: vendor=âX.Org Foundationâ
[ 47.462] compiled for 1.20.4, module version = 1.20.4
[ 47.462] Module class: X.Org Video Driver
[ 47.462] ABI class: X.Org Video Driver, version 24.0
[ 47.462] (II) LoadModule: âfbdevâ
[ 47.463] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 47.465] (II) Module fbdev: vendor=âX.Org Foundationâ
[ 47.465] compiled for 1.20.3, module version = 0.5.0
[ 47.465] Module class: X.Org Video Driver
[ 47.465] ABI class: X.Org Video Driver, version 24.0
[ 47.465] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 47.465] (II) FBDEV: driver for framebuffer: fbdev
[ 47.471] (WW) Falling back to old probe method for modesetting
[ 47.471] (EE) open /dev/dri/card0: No such file or directory
[ 47.471] (WW) Falling back to old probe method for fbdev
[ 47.471] (II) Loading sub module âfbdevhwâ
[ 47.471] (II) LoadModule: âfbdevhwâ
[ 47.471] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 47.473] (II) Module fbdevhw: vendor=âX.Org Foundationâ
[ 47.473] compiled for 1.20.4, module version = 0.0.2
[ 47.473] ABI class: X.Org Video Driver, version 24.0
[ 47.474] (II) FBDEV(0): using default device
[ 47.474] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 47.474] (II) FBDEV(0): Creating default Display subsection in Screen section
âDefault Screen Sectionâ for depth/fbbpp 24/32
[ 47.474] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 47.474] (==) FBDEV(0): RGB weight 888
[ 47.474] (==) FBDEV(0): Default visual is TrueColor
[ 47.474] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 47.474] (II) FBDEV(0): hardware: BCM2708 FB (video memory: 1500kB)
[ 47.474] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 47.474] (II) FBDEV(0): checking modes against framebuffer deviceâŚ
[ 47.474] (II) FBDEV(0): checking modes against monitorâŚ
[ 47.474] (II) FBDEV(0): Virtual size is 800x480 (pitch 800)
[ 47.474] () FBDEV(0): Built-in mode âcurrentâ
[ 47.474] (==) FBDEV(0): DPI set to (96, 96)
[ 47.474] (II) Loading sub module âfbâ
[ 47.474] (II) LoadModule: âfbâ
[ 47.474] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 47.478] (II) Module fb: vendor=âX.Org Foundationâ
[ 47.478] compiled for 1.20.4, module version = 1.0.0
[ 47.478] ABI class: X.Org ANSI C Emulation, version 0.4
[ 47.478] () FBDEV(0): using shadow framebuffer
[ 47.478] (II) Loading sub module âshadowâ
[ 47.478] (II) LoadModule: âshadowâ
[ 47.479] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 47.483] (II) Module shadow: vendor=âX.Org Foundationâ
[ 47.483] compiled for 1.20.4, module version = 1.1.0
[ 47.483] ABI class: X.Org ANSI C Emulation, version 0.4
[ 47.483] (II) UnloadModule: âmodesettingâ
[ 47.483] (II) Unloading modesetting
[ 47.497] (==) FBDEV(0): Backing store enabled
[ 47.500] (==) FBDEV(0): DPMS enabled
[ 47.501] (II) Initializing extension Generic Event Extension
[ 47.502] (II) Initializing extension SHAPE
[ 47.503] (II) Initializing extension MIT-SHM
[ 47.503] (II) Initializing extension XInputExtension
[ 47.506] (II) Initializing extension XTEST
[ 47.507] (II) Initializing extension BIG-REQUESTS
[ 47.508] (II) Initializing extension SYNC
[ 47.509] (II) Initializing extension XKEYBOARD
[ 47.510] (II) Initializing extension XC-MISC
[ 47.510] (II) Initializing extension SECURITY
[ 47.511] (II) Initializing extension XFIXES
[ 47.512] (II) Initializing extension RENDER
[ 47.513] (II) Initializing extension RANDR
[ 47.515] (II) Initializing extension COMPOSITE
[ 47.516] (II) Initializing extension DAMAGE
[ 47.517] (II) Initializing extension MIT-SCREEN-SAVER
[ 47.518] (II) Initializing extension DOUBLE-BUFFER
[ 47.518] (II) Initializing extension RECORD
[ 47.519] (II) Initializing extension DPMS
[ 47.520] (II) Initializing extension Present
[ 47.521] (II) Initializing extension DRI3
[ 47.521] (II) Initializing extension X-Resource
[ 47.522] (II) Initializing extension XVideo
[ 47.523] (II) Initializing extension XVideo-MotionCompensation
[ 47.523] (II) Initializing extension SELinux
[ 47.523] (II) SELinux: Disabled on system
[ 47.523] (II) Initializing extension GLX
[ 47.524] (II) AIGLX: Screen 0 is not DRI2 capable
[ 48.358] (II) IGLX: Loaded and initialized swrast
[ 48.358] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 48.358] (II) Initializing extension XFree86-VidModeExtension
[ 48.359] (II) Initializing extension XFree86-DGA
[ 48.360] (II) Initializing extension XFree86-DRI
[ 48.362] (II) Initializing extension DRI2
[ 48.583] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/event0)
[ 48.583] () ADS7846 Touchscreen: Applying InputClass âevdev touchscreen catchallâ
[ 48.583] () ADS7846 Touchscreen: Applying InputClass âlibinput touchscreen catchallâ
[ 48.583] () ADS7846 Touchscreen: Applying InputClass âTouch rotationâ
[ 48.583] (II) LoadModule: âevdevâ
[ 48.583] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 48.588] (II) Module evdev: vendor=âX.Org Foundationâ
[ 48.588] compiled for 1.20.3, module version = 2.10.6
[ 48.588] Module class: X.Org XInput Driver
[ 48.588] ABI class: X.Org XInput driver, version 24.1
[ 48.588] (II) Using input driver âevdevâ for âADS7846 Touchscreenâ
[ 48.588] () ADS7846 Touchscreen: always reports core events
[ 48.588] () evdev: ADS7846 Touchscreen: Device: â/dev/input/event0â
[ 48.588] (â) evdev: ADS7846 Touchscreen: Vendor 0 Product 0x1ea6
[ 48.588] (â) evdev: ADS7846 Touchscreen: Found absolute axes
[ 48.588] (â) evdev: ADS7846 Touchscreen: Found x and y absolute axes
[ 48.588] (â) evdev: ADS7846 Touchscreen: Found absolute touchscreen
[ 48.588] (II) evdev: ADS7846 Touchscreen: Configuring as touchscreen
[ 48.588] () evdev: ADS7846 Touchscreen: YAxisMapping: buttons 4 and 5
[ 48.588] () evdev: ADS7846 Touchscreen: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 48.588] () Option âconfig_infoâ âudev:/sys/devices/platform/soc/3f204000.spi/spi_master/spi0/spi0.1/input/input0/event0â
[ 48.588] (II) XINPUT: Adding extended input device âADS7846 Touchscreenâ (type: TOUCHSCREEN, id 6)
[ 48.589] (II) evdev: ADS7846 Touchscreen: initialized for absolute axes.
[ 48.589] () ADS7846 Touchscreen: (accel) keeping acceleration scheme 1
[ 48.589] () ADS7846 Touchscreen: (accel) acceleration profile 0
[ 48.589] () ADS7846 Touchscreen: (accel) acceleration factor: 2.000
[ 48.589] () ADS7846 Touchscreen: (accel) acceleration threshold: 4
[ 48.589] () Option âTransformationMatrixâ â0 1 0 -1 0 1 0 0 1â
[ 48.591] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/mouse0)
[ 48.591] (II) No input driver specified, ignoring this device.
[ 48.591] (II) This device may have been added with another device file.
nothing happens,
Did you try the alternative ads7846 overlay file from goodtft I mentioned earlier?
the screen seems fine but the touch function still not working the mouse is in the middle.
