I got the Mini86 with internal HD delivered few days ago and I’m happy with the performance so far.
The problem I have is playing songs from the internal HD. I get an error message popping up on the gui which says “failed to open ALSA device on hd1,0 device”.
Library scan and playing from the NAS works as expected.
Second airplay did not play. It appeared in iTunes but did not play. I updated to the latest release.
The error you see means that the device cannot find the audio device on hw:1. This is probably due to an “improvement” we’ve made in latest release, which sets USB device to hw:5. The solution to this is really simple: just go to playback, and select again your USB DAC, then save.
Sorry for the inconvenience
let me know how it goes and also I would be curious to know what you think of the mini86!
Regarding the Mini86. So far I am quite impressed.
Delivery was convenient. The parcel arrived after two weeks directly from China.
No installation required. Connection to the hotpot and changing network was easy. The same is true for scanning the library - the reason why I gave up my Cubox. Considering my huge library consist mainly of HiResAudio with 24/96, 24/192 and DSD I must say, scanning the NAS was very fast and painless.
My Teac UD501 DAC was immediately recognized. Also my FAT32 USB hard drive mounted straight away. I connected to the internal HD manually with smb on OSX (not autodetected on OSX) . Airplay is more or less stable (Sierra sucks)
For me most important: NO dropouts with HiResAudio and the GUI stays always very responsive! The soundquality is out of heaven The only glitch at the moment: DSD direct to the UD501 seems not work. The Display on the DAC says PCM354,8
It is still new and I don’t have that much experience yet. Using the wired connection, I did not check WIFi yet for example. But so far absolutely great, well worth the money. And yes, it is out of-the-box: Unpack, plug, scan and play!
And any idea why DSD direct to the UD 501 shows PCM 354,8 on the DAC and not DSD?
That means the DSD gets converted to PCM 354,8 even though I set “DSD direct” in the playback settings.
This means that your DAC is not compatible with DSD Direct, that’s why Volumio (actually mpd) resamples to the highest PCM bitrate supported by your DAC. Is DoP working?
