I have just installed volumio and it’s great ! I use it on a rpi 2, with a usb disk connected and a VDac 2. I would like to be able to read the music on that disk with another system, that can read only music from a dlna server (bose soundtouch). So I would like to run a mindlna on the pi. However, I don’t manage to do it. : I can install it (sudo apt-get install minidlna), however, the service doesn’t seem to start if I reboot the pi, I can’t see it using ps -aux | grep dlna. The conf file hasn’t be created either. I’m a bit confused, it’s probably something simple, but I can’t see what happen. Any ideas ?
it seems to works ! now ps -aux|grep dlna send me back something ! however, I can’t find the minidlna .conf and therefore don’t know how to set the server. more pointers ?
I want to have the db on the external usb hd media/HDD/server but it always failed to write the files.db
It’s a permission problem which I can’t solve and asking for help how to manage this.
This didn’t work for me to enable dlna. The only thing I can figure is that I should have created /lib/systemd/system/minidlna.service as root, e.g for permission purposes. Does that sound correct?
I get>>
volumio@volumio:~$ sudo systemctl enable minidlna.service
Synchronizing state for minidlna.service with sysvinit using update
rc.d…
Executing /usr/sbin/update-rc.d minidlna defaults
Executing /usr/sbin/update-rc.d minidlna enable
Failed to execute operation: Bad message<<
unfortunately the minidlna plugin is not available from the plugins management in the UI yet. In order to install it manually connect to Volumio via ssh and try the following:
