Migrating Nanosound plug-in to volumio 3
We are in the process of migrating our plugin to volumio 3 and is hitting some issues with installation of dependency library. It worked with vanilla Raspbian buster but hit issue with volumio 3. Any help would be highly appreciated.
Volumio Information
Volumio Version: 3.173
Hardware: Raspberry Pi 4
DAC:NanoSound DAC 2 pro
Debug Log
Steps to Reproduce
ran below beforehand
sudo apt-get update
When we run:
sudo apt install libsdl-dev libportmidi-dev libsdl-ttf2.0-dev libsdl-mixer1.2-dev libsdl-image1.2-dev
The following error appear:
The following packages have unmet dependencies:
libsdl-image1.2-dev : Depends: libsdl-image1.2 (= 1.2.12-10+deb10u1) but it is not going to be installed
libsdl-mixer1.2-dev : Depends: libsdl-mixer1.2 (= 1.2.12-15) but it is not going to be installed
libsdl-ttf2.0-dev : Depends: libsdl-ttf2.0-0 (= 2.0.11-6) but it is not going to be installed
libsdl1.2-dev : Depends: libsdl1.2debian (= 1.2.15+dfsg2-4+rpt2) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Additional Information
The /etc/apt/sources/list remained unchanged as
deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free
We also tried using aptitude but didn’t help much.
Problem is solved (by using pip3 install instead of apt-get)
Is your code hosted somewhere? Someone can have a look if you still have issues…
Problem is solved earlier. We are working on the release. Code is in our github repo in GitHub - nanomesher/Nanomesher_NanoSound: Source code for NanoSound products
tried to install the nanosound plugin on volumio 3.512 with ssh:
cd /home/volumio
wget https://github.com/nanomesher/Nanomesher_NanoSound/raw/master/packages/install_nanosound_for_v3.sh
chmod +x install_nanosound_for_v3.sh
./install_nanosound_for_v3.sh
I see it in the plugins now, active but have error messages. OLED and remote do not work.
Any idea to solve it? (i want to use the pi switch cap)
Thanks in advance
can you generate the log from the failed install?
Maybe it shows something more.
hopefully…
http://logs.volumio.org/volumio/M97Igmi.html
As far as I can see, service are not generated or started.
Please create them manually. If the files already exist then only perform the execution part per service.
nanosound_lirc.service
sudo nano /lib/systemd/system/nanosound_lirc.service
Copy/paste and save:
[Unit]
Description=NanoSound LIRC Service
[Service]
ExecStart=/home/volumio/nanosound_oled/nanodac_lirc.py
StandardOutput=null
[Install]
WantedBy=multi-user.target
Alias=nanosound_lirc.service
Execute:
sudo chmod 644 /lib/systemd/system/nanosound_lirc.service
sudo systemctl daemon-reload
sudo systemctl enable nanosound_lirc.service
sudo systemctl start nanosound_lirc.service
nanosound_oled.service
sudo nano /lib/systemd/system/nanosound_oled.service
[Unit]
Description=NanoSound OLED Diplay Service
[Service]
ExecStart=/home/volumio/nanosound_oled/nanodac_oled.py
WorkingDirectory=/home/volumio/nanosound_oled
StandardOutput=null
[Install]
Alias=nanosound_oled.service
Execute:
sudo chmod 644 /lib/systemd/system/nanosound_oled.service
sudo systemctl enable nanosound_oled.service
sudo systemctl start nanosound_oled.service
nanosound_rotary.service
sudo nano /lib/systemd/system/nanosound_rotary.service
[Unit]
Description=NanoSound Rotary Volume Control
[Service]
ExecStart=/home/volumio/nanosound_oled/nanodac_rotary.py
StandardOutput=null
[Install]
Alias=nanosound_rotary.service
Execute:
sudo chmod 644 /lib/systemd/system/nanosound_rotary.service
sudo systemctl enable nanosound_rotary.service
sudo systemctl start nanosound_rotary.service
Thank you for the quick response.
i did that but no function. :man_shrugging:
http://logs.volumio.org/volumio/xe6XlU1.html
what happens if you run:
python3 /home/volumio/nanosound_oled/nanodac_oled.py
python3: can’t open file ‘/home/volumio/nanosound_oled/nanodac_oled.py’: [Errno 2] No such file or directory
Probably because not the correct arch.
Then you have found the error. The services expect the folder on the missing location.
So where did it go?
There is something really wrong with the installer. Services won’t start due to missing files.
I ran it on my dev device, I see the plugin is installed, but no files are present.
This is something I can’t solve. Please get in contact with the creator of the plugin.
nanosound_oled.zip (5.5 MB)
If you unzip this file to /home/volumio the plugin will start,
did not find it on the hole device. :man_shrugging:
with the installation of the nanosoundone plgin at least the remote control works :crazy_face:
I will try to get missing files at the weekend.
Thanks again.
euh read my previous post…
Thank you.
i was to slow sending message…
i put the files in the directory, but an error occurs.
volumio@iqaudio:~$ python3 /home/volumio/nanosound_oled/nanodac_oled.py
  File "/home/volumio/nanosound_oled/nanodac_oled.py", line 17, in <module>
    import schedule
ModuleNotFoundError: No module named 'schedule'
How did you get the plugin installed, @Wheaten ?
It seemed like you had the same hardware…
Thank you.
Just followed the instructions as given by yourself:
cd /home/volumio
Unzipped the previous uploaded zip to /home/volumio
Manually installed the services.
I don’t have the hardware, just a rPi with a SDD1306 to test.
