Metrum Acoustics ONYX DAC3
Hello.
I am a Metrum Acoustics ONYX DAC3 owner that replaced a Cyan Holo 2.
I just inserted the new DAC into the playback chain but Volumio does not recognize the new DAC. The Holo 2 remains among the audio sources and in the drop-down menu there is no trace of any other DAC.
What should I do?
Is Volumio compatible with Metrum Acoustics ONYX DAC3?
If I try to update Volumio it also tells me that there are files that have been changed and that I should restore everything.
This is quite annoying because the personal configuration of Volumio takes time. I am currently on version 3.779.
It seems that selecting the audio output as Hifacetwo UAC 2 the DAC works. Before with the Holo Cyan 2 I saw the same name as the source. This does not happen with the ONYX. Is this correct?
You know on a community board, we fully depend on the information you give us.
So far all we know is a DAC name and Volumio version.
  • Is this a USB or i2c DAC?
  • What hardware do you use for Volumio?
  • Which plugins are installed?
  • Post a log
output of:
cat /boot/config.txt
cat /boot/userconfig.txt
In your OP you wrote that there is no further DAC in the dropdown list.
Now you write that you selected “Hifacetwo UAC 2”.
At least confusing😉
Log still welcome…
What is printed/labeled on the DAC housing does not necessarily mean that the software internally returns the same name. It is what the supplier decided, it is the name returned by the used usb interface, quite normal.
What plugins do you have installed?
Sorry! You are absolutely right!
The connection to the DAC is with USB 2.0
I use the Raspberry.
The plugins installed are:
  • AutoStart
  • GPIO Buttons
  • Touch Display
  • Now Playing
  • System Information (and this is the report from this plugins)
  • OS info
  • Version of Volumio: 3.785
  • Hostname: volumio
  • Kernel: 6.6.62-v7l+
  • Governor: performance
  • Audio info
  • Hw audio configured: hiFaceTWO UAC2
  • Mixer type: Hardware
  • Number of channels:
  • Supported sample rate:
  • Board info
  • Manufacturer: Raspberry Pi Foundation
  • Model: Raspberry Pi 4 Model B Rev 1.5 Raspberry Pi / 4B - 1.5 /
  • Version: c03115 / 4B - 1.5
  • Firmware Version: Nov 11 2024 15:48:13 version 903570ba72a9e117f92e5499de439f59dd96e417 (clean) (release) (start)
  • CPU info
  • Brand: BCM2711
  • Speed: 1.5 GHz
  • Family: Cortex-A72
  • Model: 3
  • Number of cores: 4
  • Physical cores: 4
  • Average load: 41%
  • Temperature: 56°C
  • Memory info
  • Memory: 3876516 Ko
  • Free: 1530292 Ko
  • Used: 2346224 Ko
  • Software info
  • Mpd version: Music Player Daemon 0.23.15 (0.23.15)
This is log:
LOG
Given the update problems, I restored to factory values ​​and redid the setting.
The DAC name is also not recognized but if I select, the DAC receives the signal from the Raspberry and it seems to work.
As with the Holo, I expected to find the DAC name.
Before the restore I had installed peppymeter screensaver which requires manual intervention on the config to make it work. I think that’s what blocks the update but it’s so frustrating… Is there a way to install peppymeter screensaver and be able to do the updates without going back to factory data every time?
Just disable Peppy_Meter, Update Volumio, enable Peppy_Meter.
