I’m seeing the sudo journalctl -f command while playing from the RadioParadise plugin and I have this message continuously:
Mar 28 00:25:46 volumio volumio [1245]: amixer: Unable to find simple control ‘Digital’, 0
What is it about?
I guess you are using a plugin such as equalizer… Since the last version of volumio, something is wrong. I try to find how to fix it.
OK
