Hi all,
I have a question regarding Media Servers / dlna browser:
When I connect volumio via dlna to my NAS, I get a result only of a part of all available folders, it stops exactly after 1000 entries.
Is there any possibility to enlarge this number of possibly folders provided by the dlna Server?
In the meantime, I have found a small workaround for this issue:
You just need to connect via ssh to the system and search and edit the file dlna-browser.js
Search for options.requestCount = 1000; and change it into options.requestCount = 10000; and reboot the system. But pls. undo this change before you plan to run an update because otherwise the update will fail. After installing the update you can re edit this file again.
