Media Server not visible on wired LAN
Hi All
I have a problem in that my Media Server (MiniDLNA on Ubuntu) is only visible on the Wireless LAN. When I disable the wireless interface on MiniDLNA and only have the wired network enabled, I cannot access the Media server through Volumio (Version 3 with Virtuoso subscription), though I had the same issue on Version 2).
I have tested my MiniDLNA wired connection with my Yamaha device and it is configured correctly.
Any idea?
Thank you.
After a restart of my Primo, my media server (NAS) wasn’t visible anymore, although it was present on my router. After some searcing I found the solution; toggle the “DNLA browser” switch under Sources.
