Hello
I am before buying a Marantz 7005 with a USB B dac and before buying a raspberry pi 3b + or
(please advise me which model is better to choose, it will only be for music, I don’t want
to assume
no fans must operate on passive cooling).[size=1]whatsapp web 192.168.0.1 routerlogin
[/size]
On Raspberry Pi I want to put the Volumio system and it will only serve me as a transport
to
Tidal, Spotify and Tunein radio with Raspberry usb A to Marantz 7005 on usb B with usb
cable.
I want to use Raspberry only to connect only with this USB cable to Maranzt, I don’t want
to
mount an additional HiFi Berry card.
My question is will my Marantz detect Raspberry connected to me via this usb cable?
Do I need to add any Rasberry usb-audio drivers to Volumio?
If all this works, will the sound be of the same good quality (of course
Spotify and Tidal) how does this happen in the integrated newer Marantz 7000N? (
which has everything already integrated on the Heos platform and plays it sensational, but
I listened
it’s only very short while listening to the store)?
I will add that I do not want to have Heos platform only in that it is often hung,
disconnects (many descriptions are on other forums).
Thank you in advance for your response.
Regards
