Hi, I am trying to find a way to enable/disable the fusiondsp plugin from the commandline, so that I can toggle it with a remote control.
I basically tried to do this:
volumio stop
change the settings in /data/configuration/plugins.json to enable/disable the plugin
volumio start
However, this has absolutely no effect. It seems that the plugins.json isn’t used. I also tried to modify the fusion_dsp/config.json and restart volumio, but that also has no effect.
Is there any way around this? Any way I could change the configuration in a way that volumio will recognize it? Going into the plugins / installed_plugin menu in the UI each time I switch from speakers to headphones is just too much hassle, so would love to have a shortcut for it.
How can I easily switch the profiles? The only way I know is quite lenghty:
open the “burger menu” with the three lines on the top left
click on Plugins
click on Installed Plugins (not shown by default, bad UX design)
click on FusionDSP/Settings
scroll down a couple of pages
select a new preset and apply it
close the menu
7 steps to switch the DSP on/off… from a UX perspective that is really annoying, hence my toying around with the settings / remote control.
Your screenshot shows a view I have never seen - does that mean there is an easier way?
I am on volumio 3.661 on a raspberry pi, with a virtuoso subscription.
OMG - THANK YOU!
I kept trying to understand what you meant with the hub - in years of using it, I never clicked on that little speaker logo. Feel stupid now, but much happier
Thank you again - FusionDSP is why use volumio…
