…however my iPhone volumio app can connect and control the same two nodes using the same wiifi network.
On the laptop I can access both nodes using either a hostname or IP address, but I would prefer having one stop shopping by getting myvolumio,org to work (it has worked in the past).
Thanks but those screens are the ones I can’t get to, The screen I have shows a list of nodes, I click on a green play triangle, and watch an “hourglass” type icon spin for eternity.
Hi, have you tried accessing “yourdevicename.local” on the browser you’re using in macOS instead of myVolumio.org? That is, in the browser address bar, use http://volumio.local , where “volumio” is your device’s name.
EDIT: never mind, I’ve just re-read this: “On the laptop I can access both nodes using either a hostname or IP address” . Please ignore.
