I am currently testing volumio on a Raspberry Pi3 with an M2Tech HiFace; everything in default config.
The DSP is recognized and plays fine, however when I skip to the next track a crack/pop noise is produced. Transition between tracks without interaction (thus the queue just roles) works fine.
I already tried to force the output format via mpd.conf, which did not help.
I’m currently using a M2 Tech high face DAC along with a pi3 B+ with volumio version 2.657 and have not any issues with popping or clicking.
Some where I read the newer M2 Tech had issues. I’m using an older one about 4 years old.
Thx for the reply, I also have this DAC in another setup, indeed a great DAC.
In the problematic setup it is the first one over there: http://www.newaudio.it/m2tech5.htm (no typo), which is also an older model.
Supplementary information about the setup:
From the DSP it goes directly to a Behringer DEQ2496 which also performs the DA-part; then to the amp and to the speakers.
The click/pop noise is proportional to the volume setup in the software mixer
