Hey guys,
Lyrics on volumio would be a great feature. Will you do this in the near future?
Greetings Daniel
same feature request
+1
+1!
Maybe an integration with Genius Lyrics (https://genius.com/) could be possible.
I’m not an expert, but here’s the documentation on their API: https://docs.genius.com/, maybe something can be done!
It would be great! It would make Volumio even more complete!
Anyone interested in this option? Any developer who has some free time?
Hi Ema82!
We’re working on it just now…
Thanks for the hint
My best
Davide
VOLUMIO PRODUCT SPECIALIST
Wow! Wonderful news! Thanks!
+1 That’s a good news!
For the way to switch from Artist Info/Album… etc… and future lyrics options It would be better have some buttons under Artist and Song names instead of current pop-up panel hidden under the 3 dots.
We are investigating on how to do it.
Mainly, contacting legit lyrics services providers.
We will keep you posted
Hello Davide!
Any news on the lyrics front?
We received a couple of proposals from Lyrics services.
The bad news is that it’s really expensive to license lyrics
But we are not stopping our search
Thanks!
Hi, I have lyrics of most of my flacs in their tags. Displaying embedded lyrics within volumio would have to wait for implementing a lyrics service into volumio? thanks
For several reasons, I am currently not running Volumio and switched to somehting else.
That has indeed lyrics.
Don’t know how they’re doing it… but it is quite nice.
As a “workaround” you can use “Neutron” app to remote control your Volumio device.
And that app includes Lyrics and I think they’re doing it from the embedded tags.
Problem : that app costs 10€. There’s a free eval version, but it will expire after 30 minutes
I bought it but do not use it, because I found out it does not handle the “Disk” tag well enough. So if I listen to, say, a complete set of piano concertos, it will play track 1 of Disk 2 ofter playing Track 1 of disk 2… Not superbly convenient unless I retag my whole library… ANd that is painful to do when you have 40 different interpretations of the Beethoven Piano Concertos and 40 interpretations of the 9 Beethoven symphonies, not to mention the Mahler and Dvorak symphonies.
Same feature request!
In my opinion, the fastest way to get the lyrics is through the ‘Now Playing’ plugin; if configured correctly, it seamlessly integrates with Genius, where you usually find an abundance of lyrics.
Wirh the „now playing“ plugin i can only see the lyrics on the display in my device. But i want to the lyrics in the web gui or in the volumio app.
Radio Paradise has lyrics, so it shouldn´t be that expensive. What is the actual state of this request? Lyrics would be grat to have.
I’d like to boost the proposal that the interface show lyrics that are already in song tags. No need for a service.
