Hi.
I have DAC Luxman DA-250 connected to RaspberryPI with Volumio via USB. DAC type is detected automatically by Volumio and I see exactly DA-250 in output device configuration. PCM streaming works correctly. DAC shows bitrate and sample rate on embedded screen.
But DSD playback is not performed- tested on DSD64 and DSD128 sources. Special indicator lits instead -Digital signal unlock indicator / In owners manual it means “the digital input signal from the digital device is not synchronized with this unit”. Also I found a version that this indicator means that DAC cant detect source type.
Besides - such files are played if DAC is connected to Windows PC from native Luxman player application (thу simplest one- with only one function- play a file).
I also tried DSD over PCM in Volumio with no result (DAC doesn’t support this mode).
For windows- a special driver exists, and if DAC is automatically detected in Volumio I guess- such driver exists in Volumio too.
Can anyone suggest- what could be the next step?
gkkpch
October 12, 2021, 9:02pm
2
could you tell us which version of Volumio (please don’t say “latest”) you are using and please give us output from “lsusb”?
Also which PI?
Thanks gkkpch for a quick answer.
Volumio 2.909. RaspberryPI 3b+.
Here is the entire output of lsusb
Bus 001 Device 007: ID 1852:5066 GYROCOM C&C Co., LTD
Bus 001 Device 004: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
And here comes the verbose output if it could be helpful
Couldn’t open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2 ?
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 64
idVendor 0x1852 GYROCOM C&C Co., LTD
idProduct 0x5066
bcdDevice 0.01
iManufacturer 1
iProduct 2
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 291
bNumInterfaces 3
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 0mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 1 Audio
bFunctionSubClass 0
bFunctionProtocol 32
iFunction 0
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
bInterfaceProtocol 32
iInterface 4
AudioControl Interface Descriptor:
bLength 9
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdADC 2.00
bCategory 8
wTotalLength 72
bmControl 0x00
bLength 8
bDescriptorType 36
bDescriptorSubtype 10 (CLOCK_SOURCE)
bClockID 41
bmAttributes 0x03 Internal programmable Clock
bmControls 0x07
Clock Frequency Control (read/write)
Clock Validity Control (read-only)
bAssocTerminal 0
iClockSource 0
bLength 8
bDescriptorType 36
bDescriptorSubtype 11 (CLOCK_SELECTOR)
bUnitID 40
bNrInPins 1
baCSourceID( 0) 41
bmControls 0x03
Clock Selector Control (read/write)
iClockSelector 0
bLength 17
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 2
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bCSourceID 40
bNrChannels 2
bmChannelConfig 0x00000000
bmControls 0x0000
iChannelNames 0
iTerminal 0
bLength 18
bDescriptorType 36
bDescriptorSubtype 6 (FEATURE_UNIT)
bUnitID 10
bSourceID 2
bmaControls( 0) 0x00000000
bmaControls( 1) 0x0000000c
Volume Control (read/write)
bmaControls( 2) 0x0000000c
iFeature 0
bLength 12
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 20
wTerminalType 0x0301 Speaker
bAssocTerminal 0
bSourceID 10
bCSourceID 40
bmControls 0x0000
iTerminal 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Streaming
iInterface 5
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
iInterface 5
AudioStreaming Interface Descriptor:
bLength 16
bDescriptorType 36
bDescriptorSubtype 1 (AS_GENERAL)
bTerminalLink 2
bmControls 0x00
bFormatType 1
bmFormats 0x00000001
PCM
bNrChannels 2
iChannelNames 0
bLength 6
bDescriptorType 36
bDescriptorSubtype 2 (FORMAT_TYPE)
bFormatType 1 (FORMAT_TYPE_I)
bSubslotSize 2
bBitResolution 16
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 5
Transfer Type Isochronous
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x0168 1x 360 bytes
bInterval 1
AudioControl Endpoint Descriptor:
bLength 8
bDescriptorType 37
bDescriptorSubtype 1 (EP_GENERAL)
bmAttributes 0x00
bmControls 0x00
bLockDelayUnits 0 Undefined
wLockDelay 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 17
Synch Type None
Usage Type Feedback
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
iInterface 5
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
iChannelNames 0
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 24
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 2
iInterface 0
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
iChannelNames 0
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 32
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0 No Subclass
bInterfaceProtocol 0 None
iInterface 7
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.10
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 35
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 9
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 255 Vendor Specific Class
bDeviceSubClass 0
bDeviceProtocol 255
bMaxPacketSize0 64
idVendor 0x0424 Standard Microsystems Corp.
idProduct 0x7800
bcdDevice 3.00
iManufacturer 0
iProduct 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 39
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 2mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 255 Vendor Specific Class
bInterfaceProtocol 255
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 4
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0 Unused
bDeviceProtocol 2 TT per port
bMaxPacketSize0 64
idProduct 0x2514 USB 2.0 Hub
bcdDevice b.b3
iManufacturer 0
iProduct 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 41
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 2mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0 Unused
bInterfaceProtocol 1 Single TT
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 1
bInterfaceProtocol 2 TT per port
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bMaxPacketSize0 64
bcdDevice b.b3
iManufacturer 0
iProduct 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 41
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 2mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 4.19
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
gkkpch
October 13, 2021, 7:16am
4
There is no DSD support for device 1852:5066 in kernel 4.19.y, used with Volumio 2.
Kernel 5.4.y, used with Volumio 3, does not have it either.
Luxman should have this device registered in the USB audio driver, otherwise there will be no linux support.
Mmm.
Is there an option to do it somehow without Luxman? I don’t think they will. May be some workaround?
And the second question- how did you get this info- is there a regisrty of supported devices? I’m thinking about changing the DAC (Accuphase) and looking for option to check compatibility with Volumio before purchasing. I saw a registry of supported DACs in this forum, but there is no information on target model.
gkkpch
October 13, 2021, 10:23am
6
Unfortunately not, for RPi we take the kernel package straight from the Rap erry foundation, for X86 we take the kernel directly from kernel.org and only compile. The only thing that works is a simple modification of the quirk list in the audio driver, that is Luxman’s job to initiate, there is no workaround.
It is a hard-coded list in the audio driver sources, which is where I get my info from.
Ask in the forum before you buy, you need to supply the vendor and product ID (mmmm:nnnn) in cases where it is not obvious which make/model the targeted DAC is. The DACs are registered with these id’s.
Can I do it for myself? For sure it will be wiped out with every release, but I can return it back. Is it a compiled module or a configuration file?
P.S.
suppose we are talking about this method
linux/sound/usb/quirks.c at f4d0cc426f77df6890aa868f96c2de89686aae8a · torvalds/linux · GitHub
and I should add something like
case USB_ID(0x1852, 0x5066): /* Luxman */
and than recompile wherever this source is included. A tricky way, but will it help?
I’m also thinking about request to Luxman team, but I need to have correct explanation- what they have to do.
gkkpch
October 13, 2021, 1:08pm
8
You would have to recompile the exact same kernel version as used for Volumio, grab the compiled
snd-usb-audio.ko module and copy it to Volumio.
But, you will probably loose OTA, meaning you can only flash a new Volumio version and with each update you need to check whether the kernel version in Volumio has changed and then do the same thing with the correct kernel sources again.
A lot of work…
You modification is not quite complete and not in the right place.
It has to be added to snd_usb_interface_dsd_format_quirks
usleep_range(5000, 6000);
* snd_usb_interface_dsd_format_quirks() is called from format.c to
* augment the PCM format bit-field for DSD types. The UAC standards
* don't have a designated bit field to denote DSD-capable interfaces,
* hence all hardware that is known to support this format has to be
* listed here.
u64 snd_usb_interface_dsd_format_quirks(struct snd_usb_audio *chip,
struct audioformat *fp,
unsigned int sample_bytes)
struct usb_interface *iface;
/* Playback Designs */
if (USB_ID_VENDOR(chip->usb_id) == 0x23ba &&
USB_ID_PRODUCT(chip->usb_id) < 0x0110) {
switch (fp->altsetting) {
case 1:
You need to find out, whether DSD capability is on altset 2 or 3.
Do a cat /proc/asound/card5/stream0 to find that.
Then add your line to the correct place in the code.
I would advice against it, but it is not forbidden if you know what you are doing :))
Better have Luxman handle it.
I see this line
And I see kernel patch- how it was introduced.
ALSA: usb-audio: Add native DSD support for Luxman DA-06 · torvalds/linux@7142653 · GitHub
It describes another model (actually a successor of my DAC). and they differ in second field 0x5065 for DA-06 versus 0x5066 for DA-250.
Can you please check- is this one included to Volumio 2/3?
And another question- How could I enable automatic DSD resampling to PCM? Currently I see no such option for DSD playback mode.
gkkpch
October 13, 2021, 9:18pm
11
No, there are no entries for DA-06 or DA-250.
I do not know where you found the patch for the DA-06, it never made the official kernel. As you now know how to check this, you will see by yourself.
* listed here.
case 1:
Above is kernel 5.10.y, so not even in the latest longterm support version.
By now I think I gave you enough info, there is nothing else I can do to help
gkkpch
October 13, 2021, 10:16pm
13
You are right, DA-06 seems to have a specific interface and is handled differently. But this does not change anything:
we don’t know whether da-250 has the same interface
da-250 is not supported anyway
Again, this is where my support ends, please ask Luxman, there is nothing Volumio can do to change it.
Sorry.
Great thanks for your help , gkkpch. You really helped me a lot.
