I am not sure, I can find no reference to it in the UI
Checked the Manual and it doesn’t.
[quote]
CIFS/SMB, AFP, HTTP/HTTPS, FTP, SFTP*, FTPS*
*LS-QVL, LS-WVL, LS-WXL, LS-VL series LinkStations only
[quote]
So tried cifs in Volumio but it failed with a ‘Host is down error’.
![Capture.JPG](/uploads/default/original/2X/8/8c56a4d02fdd0c5b65a019000c5e497a39d2a7f1.jpeg)
chsims1
22
For the Buffalo and cifs try the additional option that you had before of “vers=1.0” (and also vers=2.0, if that doesn’t work).
What does ‘smbclient -L 192.168.0.250’ report?
Adding vers=1.0 made the difference, it mounted immediately.
Thanks so much for your persistence and patience.
