hello
i think Volumio should be configurable only with Login. As Admin i attach the share, nobody else has to do it.
Also with the Login you should be able to create some Playlist, but everybody could use it…
have a nice day
vinc
Hi vinc, sorry I don’t understand what you mean by this. Do you mean the web UI or at the command line?
You can do this from the web UI.
Hello
i am writing about the WebUI.
OK, so most of the relevant configuration can indeed be done from the web UI.
yes but it should be restircted to only the Admin
