I just download Volumio 3 for a pc, and I got a new computer, and I am trying to log in, but it tells me the email is use by other account. How can I fix it?
You mean logging into myVolumio and it complains that the email is used by another myVolumio account?
In that case, contact your official support:
Why I can not log in with Volumio 3?
I don’t know, community members can’t help with myVolumio account issues.
You are entitled to dedicated support and I advise you to use the opportunity mentioned above.
Are you from Volumio?
nope, a Community Member and moderator.
Any idea how can I get help from Volumio?
Use the link I posted a few posts above. It creates a ticket and you will get contacted.
Did it work with Volumio 2, or is Volumio 3 your first one?
