Dear friends,
I’ve installed the LMS plugin but each time I want to open the LMS at myipaddress:9000 nothing happens.
Any suggestions?
Which LMS Server plugin you’re referring too, as there are 2?
What is your hardware?
Which version of Volumio?
I use the LMS plugin found in Volumio.
I have the last version of Volumio.
I use a Mano Mk2 with Raspberry 3B.
Thanks.
there are still 2 different plugins.
In my settings, I cannot find the Dockerized version, just the first one.
Then uninstall the LMS plugin and reboot.
- goto <ip-address>/dev
- Enable Plugin Test Mode
- Install the Docker version and test.
THANK YOU!!!
It works!
Thanks to @patrickkfkan
