I am getting the error libraspberrypi0_0.0.1_all.deb failed when trying to install the LCD plugin.
I see this was a certificate error but I tried the work around and it then failed to install chromium.
pi 3B+ on 32 gb sd
Partitions seem to be big enough.
Any help gratefully received.
Scott
Hi Scott,
Which plugin are you trying to install ?
Do you have a link to it ?
asfaik there is no official plugin
br
Josef
RPi LCD screen, version 3.35 in the plugins library.
i guess you are talking about the „Touch Display“ plugin, which is available in Version 3.3.5.
i recommend to rename your thread if you expect someone to help.
SimonE
5
Have tried unistalling the plugin. Power off. Power on. Reinstall plugin.
