Lintbf
May 25, 2021, 12:04pm
1
Hello friends,
I thought that it will be better to open a new thread regarding the laptop Display and controlelr board for using with Volumio and RPI or TBS .
I am looking for a 15 inch display FHD or HD to use with RPI4 .
I thinking at this :
or 13 inch
Or I should go with another models
All display has 30 pin LVDS or the can connect to other interfaces to board controller ?
dvo
May 25, 2021, 12:11pm
2
you better go with a screen already compatible with your rpi instead…
but the price will be a lot higher for 13 or 15 inch
here a 13 inch
Lintbf
May 25, 2021, 12:15pm
3
Due to this I want to go with the abive solution.
I will give it a shot. I already have a working 4.3 inch waveshare dsi display.
dvo
4
waveshare is already made for rpi…
what your showing is a laptop screen without any controllerboard…
Lintbf
May 25, 2021, 12:17pm
5
I know, a controller board is around 30 euro
dvo
May 25, 2021, 12:18pm
6
you have to match them so it will work hopefully.
do you need touch?
Lintbf
May 25, 2021, 12:27pm
7
Yes, I know…
What I do not know are the connection of the display, all are conected via lvds cable?
dvo
May 25, 2021, 12:28pm
8
you better buy a second hand monitor with hdmi …
you have all the things needed inside and that starts at 40 euro
Lintbf
May 25, 2021, 12:34pm
9
Great ideea, can you gave me a link from ebay uk. I searched but not found with hdmi.
Lintbf
May 25, 2021, 12:43pm
11
Thanks but it is too big. I need a 15 inch.
dvo
May 25, 2021, 12:45pm
12
just look for monitor 1920x1080 and in the sidebar pick hdmi and search
15.6
Best resolution: 1920x1080. High definition standard: 1080P. Can be used to combine devices with HDMI port for dual screen display, support HDMI HD 1080 input. Data + Video interface: Type-C, Mini HDMI.
the 13 inch cost more strange but true 15 inch is the standard size 13 is for a pc under sized
