Lintbf
May 22, 2020, 7:46pm
21
Ok
I need to decide to build a streamer with 4.3 waveshare or 5 inch osoyoo…
What do you think? I can not decide
Darmur
May 23, 2020, 8:21am
22
It depends if you prefer a slightly bigger screen or if you prefer to save some money.
Lintbf
May 23, 2020, 1:38pm
23
Yes…
I see that osoyoo is tft and waveshare is ips,
It will matter on this size? What is the most performant in terms of quality, resolution etc… View the artist image etc.
Thanks in advance
Hi sir am from India. volumio raspberry pi 3 b is work waveshare DSI 4.3 inch tuch screen directly? pls rply
this type 4.3 inch tuch disply waveshare DSI work volumio Raspberry directly? need eny driver?
gvolt
May 9, 2022, 7:30am
26
You just need to install the Touch Display plugin, no driver required.
Be aware that there is possibly a problem switching off the backlight when the display is rotated by 90 or 270 deg. as reported by @buma
Hello there, new to the board, but not to Volumio.
I built a stand-alone headphone music server with a Raspberry Pi 4 and a DSI monitor (WaveShare 4.3" capacitive touch display ) using the latest build of Volumio (2.917) and the Touch Display plugin (1.3.0), and no other plugins. Everything works just fine except for the Screensaver Setting - it won’t turn off.
This was a rebuild of an earlier project using the same RPi but with a different screen. The screensaver worked fine on the older scr…
and confirmed by @michel8166
set to 90 degrees and now the problem is also present, it does not turn off, the screen flickers 2x briefly, so it does make an attempt to go out, but it does not go through.
by the way the touch is at 90 degrees outline.
I also tried 270 degrees, same problem. then there is indeed a difference compared to the Raspberry Pi Foundation touchscreen.
Shame.
got to test it a little earlier.
okay a fresh install of volumio2 on a raspberry pi 3b version 1.2.
touchscreen set to 90 degrees and 20 seconds timeout and no screensaver on.
and here also the same problem after 20 seconds the screen dims slightly also at 270 degrees it does not work.
only difference is that now the touch is good.
[IMG_20211129_123059]
Waveshare suggested a hardware modification to solve the issue:
I don’t know if this works and if Waveshare has done this themselves on the current PCB layout.
i think 4.3 inch Wave share HDMI tuch display work perfectly? is it ?
gvolt
May 9, 2022, 8:16am
28
Will it work perfectly? I can’t comment on that display as I don’t own one, but the following can be noted:
In contrast to the DSI display you will have to SSH into Volumio and modify the file “/boot/userconfig.txt”.
Also the HDMI display does not support adjusting the display brightness by software (but it seems to provide an OSD menu to set brightness).
I have the waveshare 4.3" display for the little Volumio system I gave to my parents, it works fine
Darmaur
sir 4.3 inch DSI or HDMI?
Darmur sir plz upload a photo?
ok sir . which display i purchase now? DSI or HDMi am very confused now . this is my volumio player set up Apex b 250 and apex b500
Darmur
May 10, 2022, 8:25am
34
I can’t take pictures, the setup with the waveshare 4.3" display is at my parents’ place
ok i decid buy a DSI tuch display wave share 4.3 inch . its perfetly ok? just chaing songs, up and down volium , and views detials only . (work in tuch control also, or i buy HDMi which is best? im a biginar sir so i ask more times soory)
Darmur
May 10, 2022, 9:12am
36
Don’t worry, the DSI version works very well, including touchscreen
gvolt
May 10, 2022, 9:32am
37
If you are still looking for pictures of the display, forum search helps :
beautiful old ess es9018 dac including cabinet for little money.
took the khadas and touchscreen out of that Woody cabinet and built it in here.
nice all in one, music via khadas/volumio and the ess es9018 dac for tv/mac and pc.
i2s raspberry pi via volumio and the ess es9018 also works fine.
[PXL_20220307_212325053]
[PXL_20220306_131305688]
[PXL_20220317_144238120]
Made another streamer last week, now for my brother-in-law.
if you want to build it, below are the parts used for this project.
more photos are below.
pay attention! do not use the power supply Power Module A-19 2x3-20V LT1083, this will in principle get too hot and can cause problems in the long run.
therefore try to use another suitable power supply yourself.
see also post from @livs
[IMG_20210927_113814]
a bit of soldering experience is a must.
I did the cutout for the 4.3 inch SDI …
