Latest update Volumio doesn't connnect to WiFi
Does not appear in app or volumio.local.
So another sd card format and reinstallation after an update?
Can you see the Volumio hotspot in the available wifi networks?
It’s also possible that your Volumio is now on another ip address. I have an app on my phone called WiFiman that can see all connected devices on the wifi network.
No Volumio hotspot fallback wifi, and no other devices connected to my wifi
Something was broken with the update. It should have have done the fallback to hotspot as the setting was on.
please report:
  • Which hardware are you using
  • Are you using a USB Wi-Fi adapter
  • Which Version of Volumio are you using, don’t say the latest
  • Have you tried to connect your device to a network cable do determine if Wi-Fi is configured properly?
Volumio was running when I connected HDMI cable. Wireless was set to off but setting on and save, page reloads and wireless is set to off again
All this happened after the broken Volumio 3.631 update i recived.
I can only manouvre in the terminal with keybord making it difficult to connect it to wifi.
Even factory reset doesnt enable wifi hotspot.
RPi4b internal wifi
