After a reboot (system freeze) , I was unable to play anything except the first song of my playlist.
The systemd journal, show me that last_100.js was crashing the volumio.service.
Here is the problematic function :
[code]/**
listen to changes in the state, saves them and write them on file
last_100.prototype.listenState = function () {
var self = this;var socket= io.connect(‘http://localhost:3000’);
socket.emit(‘getState’, ‘’);socket.on(‘pushState’, function(data) {
var newlastStates = []; if (data.status != 'stop' && data.service != 'webradio' && data.volatile != true){ if (data.uri != currentSong.uri){ currentSong.uri = data.uri; var currentsong = {uri:data.uri, service:data.service,title:data.title, artist:data.artist, album:data.album, albumart:data.albumart, type:'song'}; newlastStates.push(currentsong); try { var lastStates = fs.readJsonSync('/data/laststates.json', {throws: false}); } catch (e) { var lastStates = []; } if(lastStates.length > 0) { var j = 0; for (var i in lastStates) { if ((lastStates[i].uri != currentSong.uri) && j < 99) { newlastStates.push(lastStates[i]); j++; } } } fs.outputJsonSync("/data/laststates.json", newlastStates); } }})
}[/code]
In my case, lastStates variable is null (problably because /data/laststates.json was unreadable), causing the crash…
I just change the condition with
if(lastStates != null && lastStates.length > 0) {
and everything works fine.
