Even with fresh card and older OS it won’t restart with large Drive attached.
Will build it fresh but no restart very strange.
Below is the logs broken into three sections because of the size restriction.
volumio@volumio:~$ lsusb
Bus 001 Device 004: ID 0bc2:3322 Seagate RSS LLC
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
volumio@volumio:~$ sudo journalctl
-- Logs begin at Tue 2018-11-27 22:42:46 UTC, end at Tue 2018-11-27 22:48:45 UTC
Nov 27 22:42:46 volumio systemd-journal[173]: Runtime journal is using 4.0M (max
Nov 27 22:42:46 volumio kernel: Booting Linux on physical CPU 0x0
Nov 27 22:42:46 volumio kernel: Linux version 4.14.29-v7+ (dc4@dc4-XPS13-9333) (
Nov 27 22:42:46 volumio kernel: CPU: ARMv7 Processor [410fd034] revision 4 (ARMv
Nov 27 22:42:46 volumio kernel: CPU: div instructions available: patching divisi
Nov 27 22:42:46 volumio kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT al
Nov 27 22:42:46 volumio kernel: OF: fdt: Machine model: Raspberry Pi 3 Model B R
Nov 27 22:42:46 volumio kernel: Memory policy: Data cache writealloc
Nov 27 22:42:46 volumio kernel: cma: Reserved 8 MiB at 0x3dc00000
Nov 27 22:42:46 volumio kernel: On node 0 totalpages: 255488
Nov 27 22:42:46 volumio kernel: free_area_init_node: node 0, pgdat 80c7edc0, nod
Nov 27 22:42:46 volumio kernel: Normal zone: 2246 pages used for memmap
Nov 27 22:42:46 volumio kernel: Normal zone: 0 pages reserved
Nov 27 22:42:46 volumio kernel: Normal zone: 255488 pages, LIFO batch:31
Nov 27 22:42:46 volumio kernel: random: fast init done
Nov 27 22:42:46 volumio kernel: percpu: Embedded 17 pages/cpu @be59f000 s38720 r
Nov 27 22:42:46 volumio kernel: pcpu-alloc: s38720 r8192 d22720 u69632 alloc=17*
Nov 27 22:42:46 volumio kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Nov 27 22:42:46 volumio kernel: Built 1 zonelists, mobility grouping on. Total
Nov 27 22:42:46 volumio kernel: Kernel command line: 8250.nr_uarts=0 bcm2708_fb.
Nov 27 22:42:46 volumio kernel: PID hash table entries: 4096 (order: 2, 16384 by
Nov 27 22:42:46 volumio kernel: Dentry cache hash table entries: 131072 (order:
Nov 27 22:42:46 volumio kernel: Inode-cache hash table entries: 65536 (order: 6,
Nov 27 22:42:46 volumio kernel: Memory: 976680K/1021952K available (7168K kernel
Nov 27 22:42:46 volumio kernel: Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB
fixmap : 0xffc00000 - 0xfff00000 (3072 kB
vmalloc : 0xbe800000 - 0xff800000 (1040 MB
lowmem : 0x80000000 - 0xbe600000 ( 998 MB
modules : 0x7f000000 - 0x80000000 ( 16 MB
.text : 0x80008000 - 0x80800000 (8160 kB
.init : 0x80b00000 - 0x80c00000 (1024 kB
.data : 0x80c00000 - 0x80c8986c ( 551 kB
.bss : 0x80c90f40 - 0x80d417f4 ( 707 kB
Nov 27 22:42:46 volumio kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=
Nov 27 22:42:46 volumio kernel: ftrace: allocating 24917 entries in 74 pages
Nov 27 22:42:46 volumio kernel: Hierarchical RCU implementation.
Nov 27 22:42:46 volumio kernel: NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Nov 27 22:42:46 volumio kernel: arch_timer: cp15 timer(s) running at 19.20MHz (p
Nov 27 22:42:46 volumio kernel: clocksource: arch_sys_counter: mask: 0xfffffffff
Nov 27 22:42:46 volumio kernel: sched_clock: 56 bits at 19MHz, resolution 52ns,
Nov 27 22:42:46 volumio kernel: Switching to timer-based delay loop, resolution
Nov 27 22:42:46 volumio kernel: Console: colour dummy device 80x30
Nov 27 22:42:46 volumio kernel: console [tty1] enabled
Nov 27 22:42:46 volumio kernel: Calibrating delay loop (skipped), value calculat
Nov 27 22:42:46 volumio kernel: pid_max: default: 32768 minimum: 301
Nov 27 22:42:46 volumio kernel: Mount-cache hash table entries: 2048 (order: 1,
Nov 27 22:42:46 volumio kernel: Mountpoint-cache hash table entries: 2048 (order
Nov 27 22:42:46 volumio kernel: Disabling memory control group subsystem
lines 28-50
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbe800000 - 0xff800000 (1040 MB)
lowmem : 0x80000000 - 0xbe600000 ( 998 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80800000 (8160 kB)
.init : 0x80b00000 - 0x80c00000 (1024 kB)
.data : 0x80c00000 - 0x80c8986c ( 551 kB)
.bss : 0x80c90f40 - 0x80d417f4 ( 707 kB)
Nov 27 22:42:46 volumio kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Nov 27 22:42:46 volumio kernel: arch_timer: cp15 timer(s) running at 19.20MHz (phys).
Nov 27 22:42:46 volumio kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
Nov 27 22:42:46 volumio kernel: sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
Nov 27 22:42:46 volumio kernel: Switching to timer-based delay loop, resolution 52ns
Nov 27 22:42:46 volumio kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
Nov 27 22:42:46 volumio kernel: Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Nov 27 22:42:46 volumio kernel: Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Nov 27 22:42:46 volumio kernel: CPU: Testing write buffer coherency: ok
Nov 27 22:42:46 volumio kernel: CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Nov 27 22:42:46 volumio kernel: Setting up static identity map for 0x100000 - 0x10003c
Nov 27 22:42:46 volumio kernel: Hierarchical SRCU implementation.
Nov 27 22:42:46 volumio kernel: smp: Bringing up secondary CPUs ...
Nov 27 22:42:46 volumio kernel: CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Nov 27 22:42:46 volumio kernel: CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
Nov 27 22:42:46 volumio kernel: CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Nov 27 22:42:46 volumio kernel: smp: Brought up 1 node, 4 CPUs
Nov 27 22:42:46 volumio kernel: SMP: Total of 4 processors activated (153.60 BogoMIPS).
Nov 27 22:42:46 volumio kernel: CPU: All CPU(s) started in HYP mode.
Nov 27 22:42:46 volumio kernel: CPU: Virtualization extensions available.
Nov 27 22:42:46 volumio kernel: devtmpfs: initialized
Nov 27 22:42:46 volumio kernel: VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
Nov 27 22:42:46 volumio kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Nov 27 22:42:46 volumio kernel: futex hash table entries: 1024 (order: 4, 65536 bytes)
Nov 27 22:42:46 volumio kernel: pinctrl core: initialized pinctrl subsystem
Nov 27 22:42:46 volumio kernel: NET: Registered protocol family 16
Nov 27 22:42:46 volumio kernel: DMA: preallocated 1024 KiB pool for atomic coherent allocations
Nov 27 22:42:46 volumio kernel: hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
Nov 27 22:42:46 volumio kernel: hw-breakpoint: maximum watchpoint size is 8 bytes.
Nov 27 22:42:46 volumio kernel: Serial: AMBA PL011 UART driver
Nov 27 22:42:46 volumio kernel: bcm2835-mbox 3f00b880.mailbox: mailbox enabled
Nov 27 22:42:46 volumio kernel: uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
Nov 27 22:42:46 volumio kernel: bcm2835-dma 3f007000.dma: DMA legacy API manager at be813000, dmachans=0x1
Nov 27 22:42:46 volumio kernel: SCSI subsystem initialized
Nov 27 22:42:46 volumio kernel: usbcore: registered new interface driver usbfs
Nov 27 22:42:46 volumio kernel: usbcore: registered new interface driver hub
Nov 27 22:42:46 volumio kernel: usbcore: registered new device driver usb
Nov 27 22:42:46 volumio kernel: raspberrypi-firmware soc:firmware: Attached to firmware from 2018-03-21 14:47
Nov 27 22:42:46 volumio kernel: clocksource: Switched to clocksource arch_sys_counter
Nov 27 22:42:46 volumio kernel: VFS: Disk quotas dquot_6.6.0
Nov 27 22:42:46 volumio kernel: VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Nov 27 22:42:46 volumio kernel: FS-Cache: Loaded
Nov 27 22:42:46 volumio kernel: CacheFiles: Loaded
Nov 27 22:42:46 volumio kernel: NET: Registered protocol family 2
Nov 27 22:42:46 volumio kernel: TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Nov 27 22:42:46 volumio kernel: TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
Nov 27 22:42:46 volumio kernel: TCP: Hash tables configured (established 8192 bind 8192)
Nov 27 22:42:46 volumio kernel: UDP hash table entries: 512 (order: 2, 16384 bytes)
Nov 27 22:42:46 volumio kernel: UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Nov 27 22:42:46 volumio kernel: RPC: Registered named UNIX socket transport module.
Nov 27 22:42:46 volumio kernel: RPC: Registered udp transport module.
Nov 27 22:42:46 volumio kernel: RPC: Registered tcp transport module.
Nov 27 22:42:46 volumio kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Nov 27 22:42:46 volumio kernel: Trying to unpack rootfs image as initramfs...
Nov 27 22:42:46 volumio kernel: Freeing initrd memory: 14312K
Nov 27 22:42:46 volumio kernel: hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
Nov 27 22:42:46 volumio kernel: workingset: timestamp_bits=14 max_order=18 bucket_order=4
Nov 27 22:42:46 volumio kernel: FS-Cache: Netfs 'nfs' registered for caching
Nov 27 22:42:46 volumio kernel: NFS: Registering the id_resolver key type
Nov 27 22:42:46 volumio kernel: Key type id_resolver registered
Nov 27 22:42:46 volumio kernel: Key type id_legacy registered
Nov 27 22:42:46 volumio kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Nov 27 22:42:46 volumio kernel: io scheduler noop registered (default)
Nov 27 22:42:46 volumio kernel: io scheduler deadline registered
Nov 27 22:42:46 volumio kernel: io scheduler cfq registered
Nov 27 22:42:46 volumio kernel: io scheduler mq-deadline registered
Nov 27 22:42:46 volumio kernel: io scheduler kyber registered
Nov 27 22:42:46 volumio kernel: BCM2708FB: allocated DMA memory fdd10000
Nov 27 22:42:46 volumio kernel: BCM2708FB: allocated DMA channel 0 @ be813000
Nov 27 22:42:46 volumio kernel: Console: switching to colour frame buffer device 80x30
Nov 27 22:42:46 volumio kernel: bcm2835-rng 3f104000.rng: hwrng registered
Nov 27 22:42:46 volumio kernel: vc-mem: phys_addr:0x00000000 mem_base=0x3f000000 mem_size:0x3f600000(1014 MiB)
Nov 27 22:42:46 volumio kernel: vc-sm: Videocore shared memory driver
Nov 27 22:42:46 volumio kernel: gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
Nov 27 22:42:46 volumio kernel: brd: module loaded
Nov 27 22:42:46 volumio kernel: loop: module loaded
Nov 27 22:42:46 volumio kernel: Loading iSCSI transport class v2.0-870.
Nov 27 22:42:46 volumio kernel: libphy: Fixed MDIO Bus: probed
Nov 27 22:42:46 volumio kernel: usbcore: registered new interface driver lan78xx
Nov 27 22:42:46 volumio kernel: usbcore: registered new interface driver smsc95xx
Nov 27 22:42:46 volumio kernel: dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Nov 27 22:42:46 volumio kernel: Core Release: 2.80a
Nov 27 22:42:46 volumio kernel: Setting default values for core params
Nov 27 22:42:46 volumio kernel: Finished setting default values for core params
Nov 27 22:42:46 volumio kernel: Using Buffer DMA mode
Nov 27 22:42:46 volumio kernel: Periodic Transfer Interrupt Enhancement - disabled
Nov 27 22:42:46 volumio kernel: Multiprocessor Interrupt Enhancement - disabled
Nov 27 22:42:46 volumio kernel: OTG VER PARAM: 0, OTG VER FLAG: 0
Nov 27 22:42:46 volumio kernel: Dedicated Tx FIFOs mode
Nov 27 22:42:46 volumio kernel: WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbdd04000 dma = 0xfdd04000 len=9024
Nov 27 22:42:46 volumio kernel: FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
Nov 27 22:42:46 volumio kernel: dwc_otg: Microframe scheduler enabled
Nov 27 22:42:46 volumio kernel: WARN::hcd_init_fiq:459: FIQ on core 1 at 0x805d2694
Nov 27 22:42:46 volumio kernel: WARN::hcd_init_fiq:460: FIQ ASM at 0x805d29fc length 36
Nov 27 22:42:46 volumio kernel: WARN::hcd_init_fiq:486: MPHI regs_base at 0xbe87e000
Nov 27 22:42:46 volumio kernel: dwc_otg 3f980000.usb: DWC OTG Controller
Nov 27 22:42:46 volumio kernel: dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
Nov 27 22:42:46 volumio kernel: dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
Nov 27 22:42:46 volumio kernel: Init: Port Power? op_state=1
Nov 27 22:42:46 volumio kernel: Init: Power Port (0)
Nov 27 22:42:46 volumio kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Nov 27 22:42:46 volumio kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 27 22:42:46 volumio kernel: usb usb1: Product: DWC OTG Controller
Nov 27 22:42:46 volumio kernel: usb usb1: Manufacturer: Linux 4.14.29-v7+ dwc_otg_hcd
Nov 27 22:42:46 volumio kernel: usb usb1: SerialNumber: 3f980000.usb
Nov 27 22:42:46 volumio kernel: hub 1-0:1.0: USB hub found
Nov 27 22:42:46 volumio kernel: hub 1-0:1.0: 1 port detected
Nov 27 22:42:46 volumio kernel: dwc_otg: FIQ enabled
Nov 27 22:42:46 volumio kernel: dwc_otg: NAK holdoff enabled
Nov 27 22:42:46 volumio kernel: dwc_otg: FIQ split-transaction FSM enabled
Nov 27 22:42:46 volumio kernel: Module dwc_common_port init
Nov 27 22:42:46 volumio kernel: usbcore: registered new interface driver usb-storage
Nov 27 22:42:46 volumio kernel: mousedev: PS/2 mouse device common for all mice
Nov 27 22:42:46 volumio kernel: IR NEC protocol handler initialized
Nov 27 22:42:46 volumio kernel: IR RC5(x/sz) protocol handler initialized
Nov 27 22:42:46 volumio kernel: IR RC6 protocol handler initialized
Nov 27 22:42:46 volumio kernel: IR JVC protocol handler initialized
Nov 27 22:42:46 volumio kernel: IR Sony protocol handler initialized
Nov 27 22:42:46 volumio kernel: IR SANYO protocol handler initialized
Nov 27 22:42:46 volumio kernel: IR Sharp protocol handler initialized
Nov 27 22:42:46 volumio kernel: IR MCE Keyboard/mouse protocol handler initialized
Nov 27 22:42:46 volumio kernel: IR XMP protocol handler initialized
Nov 27 22:42:46 volumio kernel: bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
Nov 27 22:42:46 volumio kernel: bcm2835-cpufreq: min=600000 max=1200000
Nov 27 22:42:46 volumio kernel: sdhci: Secure Digital Host Controller Interface driver
Nov 27 22:42:46 volumio kernel: sdhci: Copyright(c) Pierre Ossman
Nov 27 22:42:46 volumio kernel: mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
Nov 27 22:42:46 volumio kernel: sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
Nov 27 22:42:46 volumio kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Nov 27 22:42:46 volumio kernel: ledtrig-cpu: registered to indicate activity on CPUs
Nov 27 22:42:46 volumio kernel: hidraw: raw HID events driver (C) Jiri Kosina
Nov 27 22:42:46 volumio kernel: usbcore: registered new interface driver usbhid
Nov 27 22:42:46 volumio kernel: usbhid: USB HID core driver
Nov 27 22:42:46 volumio kernel: vchiq: vchiq_init_state: slot_zero = bdd80000, is_master = 0
Nov 27 22:42:46 volumio kernel: [vc_sm_connected_init]: start
Nov 27 22:42:46 volumio kernel: vc_vchi_sm_init: failed to open VCHI service (-1)
Nov 27 22:42:46 volumio kernel: [vc_sm_connected_init]: failed to initialize shared memory service
Nov 27 22:42:46 volumio kernel: [vc_sm_connected_init]: end - returning -1
Nov 27 22:42:46 volumio kernel: Initializing XFRM netlink socket
Nov 27 22:42:46 volumio kernel: NET: Registered protocol family 17
Nov 27 22:42:46 volumio kernel: Key type dns_resolver registered
Nov 27 22:42:46 volumio kernel: Registering SWP/SWPB emulation handler
Nov 27 22:42:46 volumio kernel: registered taskstats version 1
Nov 27 22:42:46 volumio kernel: uart-pl011 3f201000.serial: cts_event_workaround enabled
Nov 27 22:42:46 volumio kernel: 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
Nov 27 22:42:46 volumio kernel: mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
Nov 27 22:42:46 volumio kernel: mmc-bcm2835 3f300000.mmc: DMA channel allocated
Nov 27 22:42:46 volumio kernel: sdhost: log_buf @ bdd07000 (fdd07000)
Nov 27 22:42:46 volumio kernel: mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Nov 27 22:42:46 volumio kernel: mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Nov 27 22:42:46 volumio kernel: mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Nov 27 22:42:46 volumio kernel: mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Nov 27 22:42:46 volumio kernel: of_cfs_init
Nov 27 22:42:46 volumio kernel: of_cfs_init: OK
Nov 27 22:42:46 volumio kernel: Freeing unused kernel memory: 1024K
Nov 27 22:42:46 volumio kernel: Indeed it is in host mode hprt0 = 00021501
Nov 27 22:42:46 volumio kernel: mmc1: new high speed SDIO card at address 0001
Nov 27 22:42:46 volumio initramfs: Booting Volumio for for BCM2835
Nov 27 22:42:46 volumio initramfs: This script mounts rootfs RO with an overlay RW layer.
Nov 27 22:42:46 volumio kernel: mmc0: host does not support reading read-only switch, assuming write-enable
Nov 27 22:42:46 volumio kernel: mmc0: new high speed SDHC card at address aaaa
Nov 27 22:42:46 volumio kernel: mmcblk0: mmc0:aaaa SC16G 14.8 GiB
Nov 27 22:42:46 volumio kernel: mmcblk0: p1 p2 p3
Nov 27 22:42:46 volumio kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Nov 27 22:42:46 volumio initramfs: IMGPART=/dev/mmcblk0p2
Nov 27 22:42:46 volumio initramfs: IMGFILE=/volumio_current.sqsh
Nov 27 22:42:46 volumio initramfs: Boot delay (except first time) will be 5 seconds
Nov 27 22:42:46 volumio initramfs: /dev/mmcblk0p2 not detected,retrying mdev in 5 seconds
Nov 27 22:42:46 volumio kernel: usb 1-1: new high-speed USB device number 2 using dwc_otg
Nov 27 22:42:46 volumio kernel: Indeed it is in host mode hprt0 = 00001101
Nov 27 22:42:46 volumio kernel: usb 1-1: New USB device found, idVendor=0424, idProduct=9514
Nov 27 22:42:46 volumio kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Nov 27 22:42:46 volumio kernel: hub 1-1:1.0: USB hub found
Nov 27 22:42:46 volumio kernel: hub 1-1:1.0: 5 ports detected
Nov 27 22:42:46 volumio initramfs: /dev/mmcblk0p2:
Nov 27 22:42:46 volumio kernel: usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Nov 27 22:42:46 volumio kernel: EXT4-fs (mmcblk0p2): recovery complete
Nov 27 22:42:46 volumio kernel: EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Nov 27 22:42:46 volumio initramfs: Doing a 5 second delay here to give kernel load a headstart
Nov 27 22:42:46 volumio kernel: usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Nov 27 22:42:46 volumio kernel: usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Nov 27 22:42:46 volumio kernel: smsc95xx v1.0.6
Nov 27 22:42:46 volumio kernel: smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:21:43:9f
Nov 27 22:42:46 volumio kernel: usb 1-1.3: new high-speed USB device number 4 using dwc_otg
Nov 27 22:42:46 volumio kernel: usb 1-1.3: New USB device found, idVendor=0bc2, idProduct=3322
Nov 27 22:42:46 volumio kernel: usb 1-1.3: New USB device strings: Mfr=2, Product=3, SerialNumber=1
Nov 27 22:42:46 volumio kernel: usb 1-1.3: Product: Expansion Desk
Nov 27 22:42:46 volumio kernel: usb 1-1.3: Manufacturer: Seagate
Nov 27 22:42:46 volumio kernel: usb 1-1.3: SerialNumber: NA8FHGJJ
Nov 27 22:42:46 volumio kernel: usb-storage 1-1.3:1.0: USB Mass Storage device detected
Nov 27 22:42:46 volumio kernel: scsi host0: usb-storage 1-1.3:1.0
Nov 27 22:42:46 volumio kernel: scsi 0:0:0:0: Direct-Access Seagate Expansion Desk 9401 PQ: 0 ANSI: 6
Nov 27 22:42:46 volumio kernel: sd 0:0:0:0: [sda] Spinning up disk...
Nov 27 22:42:46 volumio kernel: .
Nov 27 22:42:46 volumio initramfs: Checking for USB updates
Nov 27 22:42:46 volumio initramfs: No USB device detected (when incorrect, try adding 'bootdelay=5' to your boot cmdline)
Nov 27 22:42:46 volumio kernel: EXT4-fs (mmcblk0p3): recovery complete
Nov 27 22:42:46 volumio kernel: EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
Nov 27 22:42:46 volumio initramfs: With Option:
Nov 27 22:42:46 volumio initramfs: VOLUMIO_VERSION="2.389"
Nov 27 22:42:46 volumio initramfs: Finish initramfs, continue booting Volumio
Nov 27 22:42:46 volumio systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
Nov 27 22:42:46 volumio systemd[1]: Detected architecture 'arm'.
Nov 27 22:42:46 volumio kernel: NET: Registered protocol family 10
Nov 27 22:42:46 volumio kernel: Segment Routing with IPv6
Nov 27 22:42:46 volumio systemd[1]: Inserted module 'ipv6'
Nov 27 22:42:46 volumio systemd[1]: Set hostname to <volumio>.
Nov 27 22:42:46 volumio systemd[1]: [/lib/systemd/system/mpd.service:18] Unknown lvalue 'ProtectKernelTunables' in section 'Service'
Nov 27 22:42:46 volumio systemd[1]: [/lib/systemd/system/mpd.service:19] Unknown lvalue 'ProtectControlGroups' in section 'Service'
Nov 27 22:42:46 volumio systemd[1]: [/lib/systemd/system/mpd.service:20] Unknown lvalue 'ProtectKernelModules' in section 'Service'
Nov 27 22:42:46 volumio systemd[1]: [/lib/systemd/system/mpd.service:23] Unknown lvalue 'RestrictNamespaces' in section 'Service'
Nov 27 22:42:46 volumio systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
Nov 27 22:42:46 volumio systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
Nov 27 22:42:46 volumio kernel: fuse init (API version 7.26)
Nov 27 22:42:46 volumio systemd-udevd[180]: starting version 215
Nov 27 22:42:46 volumio systemd-journal[173]: Journal started
Nov 27 22:42:46 volumio systemd[1]: Starting Slices.
Nov 27 22:42:46 volumio systemd[1]: Reached target Slices.
Nov 27 22:42:46 volumio systemd[1]: Starting Remount Root and Kernel File Systems...
Nov 27 22:42:46 volumio systemd[1]: Started Restore / save the current clock.
Nov 27 22:42:46 volumio systemd[1]: Started Create list of required static device nodes for the current kernel.
Nov 27 22:42:46 volumio systemd[1]: Time has been changed
Nov 27 22:42:46 volumio systemd[1]: Starting Create Static Device Nodes in /dev...
Nov 27 22:42:46 volumio systemd[1]: Started Create Static Device Nodes in /dev.
Nov 27 22:42:46 volumio systemd[1]: Starting udev Kernel Device Manager...
Nov 27 22:42:46 volumio systemd[1]: Mounted POSIX Message Queue File System.
Nov 27 22:42:46 volumio systemd[1]: Started Remount Root and Kernel File Systems.
Nov 27 22:42:46 volumio systemd-modules-load[171]: Inserted module 'fuse'
Nov 27 22:42:46 volumio systemd[1]: Starting Copy rules generated while the root was ro...
Nov 27 22:42:46 volumio systemd[1]: Started Various fixups to make systemd work better on Debian.
Nov 27 22:42:46 volumio systemd[1]: Starting Load/Save Random Seed...
Nov 27 22:42:46 volumio systemd[1]: Starting Local File Systems (Pre).
Nov 27 22:42:46 volumio systemd[1]: Reached target Local File Systems (Pre).
Nov 27 22:42:46 volumio systemd[1]: Mounting /tmp...
Nov 27 22:42:46 volumio systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
Nov 27 22:42:46 volumio systemd[1]: Mounting /var/spool/cups...
Nov 27 22:42:46 volumio systemd[1]: Mounting /var/log...
Nov 27 22:42:46 volumio systemd[1]: var-log.mount: Directory /var/log to mount over is not empty, mounting anyway.
Nov 27 22:42:46 volumio systemd[1]: Mounted /tmp.
Nov 27 22:42:46 volumio systemd[1]: Started Copy rules generated while the root was ro.
Nov 27 22:42:46 volumio fake-hwclock[159]: Tue Nov 27 22:42:46 UTC 2018
Nov 27 22:42:46 volumio systemd-modules-load[171]: Inserted module 'i2c_dev'
Nov 27 22:42:46 volumio kernel: i2c /dev entries driver
Nov 27 22:42:46 volumio systemd[1]: Started Load Kernel Modules.
Nov 27 22:42:46 volumio systemd[1]: Started Load/Save Random Seed.
Nov 27 22:42:46 volumio systemd[1]: Mounted /var/spool/cups.
Nov 27 22:42:46 volumio systemd[1]: Mounted /var/log.
Nov 27 22:42:46 volumio systemd[1]: Started Show Plymouth Boot Screen.
Nov 27 22:42:46 volumio systemd[1]: Mounted FUSE Control File System.
Nov 27 22:42:46 volumio systemd[1]: Starting Forward Password Requests to Plymouth Directory Watch.
Nov 27 22:42:46 volumio systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Nov 27 22:42:46 volumio systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Nov 27 22:42:46 volumio systemd[1]: Starting Paths.
Nov 27 22:42:46 volumio systemd[1]: Reached target Paths.
Nov 27 22:42:46 volumio systemd[1]: Mounting /var/spool/cups/tmp...
Nov 27 22:42:46 volumio systemd[1]: Mounting Configuration File System...
Nov 27 22:42:46 volumio systemd[1]: Starting Apply Kernel Variables...
Nov 27 22:42:46 volumio systemd[1]: Mounted /var/spool/cups/tmp.
Nov 27 22:42:46 volumio systemd[1]: Mounted Configuration File System.
Nov 27 22:42:46 volumio systemd[1]: Started Apply Kernel Variables.
Nov 27 22:42:46 volumio kernel: snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
Nov 27 22:42:46 volumio kernel: snd_bcm2835: unknown parameter 'index' ignored
Nov 27 22:42:46 volumio kernel: bcm2835_alsa bcm2835_alsa: card created with 8 channels
Nov 27 22:42:47 volumio kernel: .
Nov 27 22:42:47 volumio kernel: snd-allo-piano-dac-plus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered - will retry
Nov 27 22:42:47 volumio kernel: snd-allo-piano-dac-plus soc:sound: snd_soc_register_card() failed: -517
Nov 27 22:42:47 volumio kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Nov 27 22:42:47 volumio systemd[1]: Starting Sound Card.
Nov 27 22:42:47 volumio systemd[1]: Reached target Sound Card.
Nov 27 22:42:47 volumio systemd[1]: Found device /dev/mmcblk0p1.
Nov 27 22:42:47 volumio systemd[1]: Starting File System Check on /dev/mmcblk0p1...
