I repeat the post here.
Installed the Kodi plugin on rasp3 + Allo Boss, I connected the HDMI cable to my TV, I see Kodi perfectly. Set in Volumio Enable DAC.
I installed the Kodi YouTube plugin and I see the videos perfectly, but I do not listen to them! Is it correct to assume that it should be heard through Volumio?
What am I doing wrong?
I have same problem. I was setting DAC on and saved the setting in kodi . But it doesn’t reflected. I am still seeing DAC off in kodi setting. No output from DAC
And also for Allo BOSS DAC, it only worked for me after i disabled startup sound first and then overwriting below value in /usr/share/alsa/alsa.conf as discussed in other threads
defaults.ctl.card 1
defaults.pcm.card 1
Now Kodi sound goes to DAC… It is impressive work… Thanks again
