I’m running volumio 1.4 with an IQaudio DAC.
The boot sequence gets as far as:
Checking if shift key is held down:Error opening ‘/dev/input/event/*’: No such file or directory
Switching to ondemand scaling governor
Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: c02452e8
CPU: 0: PID: 1928 Comm: switch_cpu_gove Not tainted 3.12.18+ #673
[] (unwind_backtrace+0x0/0xf0) from [] (show_stack+0x10x0x14)
[] (show_stack+0x10/0x14) from [] (panic+0x94/0x1e4)
etc. (the rest of the instructions are as follows:)
panic+0x94/0x1e4
__stack_chk_fail+0x10/0x14
number.isra.1+0x4c/0x498
vsnprintf+0x358/0x458
snprintf+0x20/0x30
proc_flush_task+0x54/0x164
release_task+0x50/0x4c8
wait_consider_task_part.20+0x57c/0xbd0
do_wait+0xdc/0x210
SyS_wait4+0x5c/0xc0
ret_fast_syscall+0x0/0x30
I’ve reflashed the SD card and it does the same thing. Could this be hardware corruption?
