I have just installed Volumio and I am using the justboom DAC. I wish to output the sound via this DACs headphone jack and I have attached speakers. A testing station works over HDMI (yet audio jack is selected in volumio settings), when I change the settings to the justboom DAC the players says it is playing but does not function. I think maybe it is pushing sound to the composite ports? Does anyone have experience with this
Is it the JustBoom DAC, DAC HAT or DAC Zero you have got?
And which Pi version are you using?
Thanks very much
I have same problem. My configuration is raspberry pi zero with justboom zero dac. When I want start play music I get error Failed to open audio output.
Thanks for replay.
Have you followed the setup guide here - justboom.co/software/config … h-volumio/
Hello, same trouble here.
Just bought a pizero W and Justbloom digi. the board is working with the old justbloom version of Volumio but not with Volumio 2. Alsa error.
any idea ?
