A list of Italy’s web radios:
to add a station:
write a file with .pls extension in \VOLUMIO\WebRadio
for example Subasio.pls, using the Url found in the above list :
[playlist]
NumberOfEntries=1
File1=http://onair18.xdevel.com:8152
Title1=Radio Subasio
Length1=-1
Version=2
then in Volumio UI send the “Update this folder” command on Browse->WEBRADIO
and entering in WEBRADIO the new station will be added at the end of the list.
for some station this don’t work, for exemple Radio Deejay:
http://radiodeejay-lh.akamaihd.net/i/RadioDeejay_Live_1@189857/master.m3u8
is using a different codec, I don’t know if it is supported from Volumio or not.
In VLC it works, codec: MPEG AAC Audio (mp4a)
ciao
de IK0VCK op Stefano
