So, I saw the newsletter about Volumio 3, and I rushed to upgrade to see if it will help with all little issues with using Tidal, but it only made things worse.
I am using Volumio on Raspberry Pi 3B+ with Hifiberry Digi2 PRO, mainly for Tidal. I am a Virtuoso user.
With upgrade to Volumio 3:
I no longer see hifiberry as output device
When trying to connect to Tidal (through Tidal integration), I am redirected to Tidal error page.
I have no other choice but to go back to previous Volumio version.
Any ideas about the issues above?
Because trying to start Tidal on a PC or ipad doesn’t work either.
There seem to be internet issues in several places, Volumio’s external pay service supplier was also affected earlier this evening.
You need to go to playback options, enable I2S and select your Hifiberry Model.
Even if you did not do it in the past, this is the correct way to do it.
Just while reflashing my 3 home systems at the same time
Should have done one after the other, could not have happened at a worse moment
But then, I can finish the Tidal config tomorrow, just bad luck…
I did that, but there is no sound coming out. Hifiberry Digi 2 PRO is not able for selection, so I’ve selected Digi+ PRO (which is just the previous, discontinued model). It is then connected through S/PDIF to Schiit Modi 3 DAC…
You meant Tidal Connect works for you with previous version also? I may need to go back to previous version since Tidal Connect doesn’t work for me with Volumio 3. Don’t see much advantage in new VolumIO 3. I only need Tidal connect
