Issues with lates RPi Image?
i’ve done an online update to my RPi2 running volumio. After the update the device was not reachable (HTTP/SSH). so i’ve installed a freshly downloaded image… same behaviour. So now i have installed an old Volumio1 Image i had and the device works fine again.
Any clues what might go on here?
Thanks in advance!
Nobody else experiences issues?
Same problem.
I had the same problem. It is solved now but I am not sure of what was wrong. Maybe a problem of IP, Volumio was listed on the network but could not be accessed at the indicated adress.
well, what did you do about it to fix it?
As I said, I am not sure of what solved the problem. I guess at some point I cleared the Chrome “history”.
As for me the online update from 2.114 to 2.118 fails (Rasp B). Restarts properly though.
A fresh flash of the latest RPI image (03.17.17) works fin for me,
But it will not start after a reboot or a shutdown.
Anyone have the same problem?
I had a similar problem with an image of Rasbian
