Hi
no graphic elements and album art in the web version ui
In the local version (hdmi connection) all graphics are displayed correctly.
х86
this problem with a new installation, immediately
Hi
х86
Yes, of course
ps
the problem with the display of any graphic elements, immediately after a new installation
can you run and post the results of: (ssh to your x86)
volumio endpointstest
the only thing i can think of is that something went wrong during the flash of the install medium.
As the …/Undefind/api… is weird.
Please try to reflash the installation medium with raspberry pi imager or win32diskimager.
I have the x86 version.
I have created an installation usb stick several times. And did the installation from 0
I used Balena Etcher for MAC
Maybe the problem is in the x86 image
We have multiple reports with issues using Balena. Please use rufus since your on a MAC.
i am using the same image on a x86, without issues. So I don’t think it’s an image issue.
I burned the image to a usb flash drive, on win using rufus.
Loaded it from the usb stick.
No change - problem with images
Just did a fresh install of image: Volumio-3.378-2022-09-30-x86_amd64.img
And all is working as it should.
Not really, image 3.378 itself is OK. Running it on various x86 machines…
Except when it is resolution related: could you try a 1920x1080 monitor?
If that works, then try this in /opt/volumiokiosk
There is a section which looks like this:
# in case we want to cap hires monitors (e.g. 4K) to HD (1920x1080)
#CAPPEDRES="1920x1080"
#SUPPORTEDRES="$(xrandr | grep $CAPPEDRES)"
#if [ -z "$SUPPORTEDRES" ]; then
# echo "Resolution $CAPPEDRES not found, skipping"
#else
# echo "Capping resolution to $CAPPEDRES"
# xrandr -s "$CAPPEDRES"
#fi
uncomment it to look like this:
else
fi
Sorry, no clue. This is something for the core developers, does not seem x86-related at all.
Developer on github , helped solve the problem .
I have 2 eth ports in my system, and the cable was connected in eth1.
The problem was solved after switching the cable to eth0
Not the most obvious reason
Now I read it, ow yes offcoarse… (not)
