I had a scheduled appointment with Volumio support team which he’s supposed to TeamViewer in to my computer this morning at 6:40am Jan 24, 2024 (pacific time). There was NO one checking in. I guess I’ll go through this channel and may be there is someone out there who might have the same problem and perhaps a solution.
The only problem that I have with RPi5 is Volumio imported only about 10k songs (I have >100K) from my Qnap NAS and it stops. It’s a fresh install with no plugins at all. I’ve never had this issue with my RPi4-8GB, RPi4-4GB nor TBS.
I am so sorry to hear about the missing appointment. We are investigating.
Regarding your issue, in the log I just see that mpd crashes, for no apparent reason. This is going to be very tough to diagnose…
On the other end, we are about to release a new version with updated mpd, which might definetely solve this issue. If you feel, you can put your device in test mode and update to 3.601. Let us know how it goes
I apologize for any confusion.
The TeamViewer appointment was scheduled correctly, but it seems you did not accept the TeamViewer invitation in time, which is essential for direct access to your PC without requiring the password.
I regret any inconvenience caused, as without this acceptance, remote connection becomes challenging.
About the issue, we can go through it via ticket thread.
I pulled the SD card from RPi5 and update the music on RPi4 and there was no problem at all.
Then I deleted the NAS and pulled the same SD card from RPi4 and update the music on RPi5 and there was the SAME issue happened! This time it stuck at 8,666 songs, not quite make it to 10k.
Today I saw a new updated v3.629 available, so I flashed a new SD card with the 3.616 (official version) and installed on my RPi5-8GB. Before I configured anything, I updated it to v3.629.
The very first thing after update was to add a network drive. My network drive is a NAS from Qnap which has over 100k songs in my music library. I’ve never had any problem adding all my music from my NAS to either RPi4 or TBS, but with the new RPi5, the added music always stopped at around 11-12k songs on all Volumio versions below 3.629. The workaround if I wanted to use the RPi5 was to install and fully configured on RPi4 and use the SD card on the RPi5.
Today, the problem was solved, and now I have all my 100k+ songs imported successfully. I don’t know what caused the problem and how v3.629 fixed it. Thanks to the Volumio team that keeps trying to solve the problem, and finally they did it.
