Hey there,
I have a Sony UDA-1, I also have a FiiO K5 Pro. Volumio is working as well as it can with the former, as this is seemingly old enough not to support native DSD, whereas the FiiO does.
Is there any sort of work around so I can take advantage of DSD playback with the Sony? Granted, Volumio does a good job of just “converting” DSD so I can play the files back at high res PCM, but I wondered if, similar to Roon, running the client on a PC and connecting my Sony to that via USB, if I’d then get DSD decoding?
I enabled SSH and checked what the Sony is compatible with; the results below:
volumio@volumio:~$ cat /proc/asound/card*/stream0
Sony Sony USB DAC Amplifier at usb-0000:01:00.0-1.1, high speed : USB Audio
Playback:
Status: Stop
Interface 1
Altset 1
Format: S16_LE
Channels: 2
Endpoint: 7 OUT (ASYNC)
Rates: 44100, 48000, 88200, 96000, 176400, 192000
Data packet interval: 125 us
Bits: 16
Channel map: FL FR
Interface 1
Altset 2
Format: S24_3LE
Channels: 2
Bits: 24
Channel map: FL FR
Interface 1
Altset 3
Format: S32_LE
Channels: 2
Bits: 32
Channel map: FL FR
This proves connecting to my raspberry Pi for DSD decoding is impossible, but if there is a way around it, I’d be interested. Thanks!
