I have some trouble with using a IR Remote Control to add a large playlist (about 8000 .flac files from SSD connected to a Raspberry 4B 4GB RAM running Volumio v2.692) to the queue.
The command I send by the Remote Key lircrc for adding playlists to queue is always like:
begin
prog = irexec
button = KEY_F1
config = /usr/bin/curl 'http://localhost:3000/api/v1/commands/?cmd=playplaylist&name=Play%20all'
repeat = 0
end
It is fine for all smaller playlists, but when I do it for the playlist “Play all”, which contains the selected tracks from all genres, the chromium browser from Touch Display plugin is showing me a page if I would need some help. The playlist gets added correctly and plays fine. Only the screen of my TV, connected by HDMI, is not showing the Volumio page in chromium browser anymore.
This effect does not appear when I add the same playlist from the Volumio Webpage on my PC.
My workaround currently is
begin
prog = irexec
button = KEY_F1
config = /usr/bin/curl ‘http://localhost:3000/api/v1/commands/?cmd=playplaylist&name=Play%20all’; killall chromium-browse
end
Then after adding the playlist, the chromium browser is getting closed and reloading with the Volumio page.
But as this is not the real solution, I’m hoping that someone might give me a helping hand to find out which timeout or buffersize might be the reason for chromium to show the helping page.
Or maybe there is a command I did not find to load a playlist to the queue without clearing the existing one. Then I might split the playlist and load them one after the other using a macro on my Remote Control (Philips Pronto).
