Hi All
Since this is my first post, first of all a big THANK YOU to Michelangelo and all developers for having brought to us such an amazing tool. I am absolutely impressed at all levels. Simplicity of installation, the linearity of the UI and finally the quality I am getting with RaspPi with the digital board (a chinese clone of the HifiBerry Digi) matched to my Cambridge 840C used as DAC.
All fine so far, except a strange behaviour I am not able to figure out how to fix.
On majority of my media, after I select a ‘disc’ and I press to the white audio arrow, the entire track selection goes to the cue and Volumio starts playing the first track. This strangely does not happen for some discs. Only first track is sent to the cue and play does not start. If I manually play individual tracks, all work fine so tracks are not the problems.
I attach an example from tracks from a CD i ripped myself in FLAC format.
I will appreciate hints to fix this. It is the only issue on a solution that other than that is just perfect!
Alessandro - Milano
