Is it possible with Volumio Premium?
Hi all, before subscribing to Volumio Premium, I would like to know if the following behaviors are possible? I use Volumio on Rapsberry but I think it doesn’t change the behavior with volumio devices.
1 - If i synchronize 2 devices using volumio and both are in very close rooms (open kitchen and dining room), does it exist a small latence in the sound between both devices?
2 - If I added some radios in “My Favorite Radio”, is it possible to duplicate easily to the other volumio devices? If not, does it exist a solution to export all my favorites radio in a file then import it in another volumio devices?
3 - If in my rapsberry i add some cards to have 2 audio inputs, is it possible to select those inputs in Volumio as an input (one at a time of course). For example, I would like to add my TV in one input and my old Sonos Amp on the other input to be able to listen to Deezer.
In advance thank you for your answers.
Best regards.
Philippe
Hello!
some answers
there is a setting if needed
yes, everything is synchronized. You have nothing to do!
you can use at least one input. Maybe two, but I don’t know.
Hi Balbuze,
Just to be sure to understand, for the point “1”, with the specified settings, do you confirm that there won’t have latency between both devices and so we will ear exactly the same in both rooms.
Is it exact?
Thank in advance for your answer.
Philippe
Yes. If you have exactly the same hw, most of the time no need to tweak value. But for example if you use DSP, on one device it introduces a latency.You can compensate in the other device to play in phase.
:wink:
Great.
Thank you Balbuze for your answers.
Have a good day
