I have Rasp PI 4b running volumio. Also it has some local mp3 files. Is it possible to configure media library in volumio to show those local files?
A USB drive connected to the rPi should be auto discovered, no need for mapping.
Unless your USB device is unreadable?
please post a log.
Actually asking about local folder on the device itself, same device where volumio is installed.
e.g. folder /home/volumio/Music
in that case you need to copy your music files to: /data/INTERNAL
yep, working, thanks!
