Is it possibe to upgrade python to version 3.12 for Volumio OS?
To install some OLED displays, in my case, or another things for others, need the latest stable python 3.12.4 ( link ) with openssl
Current version of Volumio 3.703 has python 3.7, and I’ve to update python manually.
And this process takes more then 1 hour every time when refresh or new instance of Volumio OS.
I understand, it’s hard work to check a compatibility with all plugins and modules.
But anyway, old version 3.7 of python is not supported when you try to install some the latest additional software.
I’d also like to know if a newer version of Python 3 will be supported with a future release. I’d like to run a small app but it requires v3.9 or above.
Is anyone able to share a manual upgrade process from the current v3.7 to v3.9 or above that doesn’t break any existing features within Volumio OS?
