Subject says it all.
I bought a pi zero and a hifiberry dac zero to have a compact solution to stream spotify to my amps through volumio.
Unfortunately though that keeps stuttering.
Playing web radio works fine. Could that be a matter of “enough CPU power”? Did I make a bad choiche?
Thanks!
I am assuming you are using the volspotconnect2 plugin?
Could you share some logs?
Either from the /dev page using the livelog feature or via ssh.
# Volumio logs
journalctl -f
# vollibrespot logs
journalctl -f -u volspotconnect2.service
Note you might need sudo before these commands depending on the version of Volumio your running
Please do this when you are seeing the stuttering issues.
